Vacuum gauge Mitsubishi Lancer
Hello!
I bought a mechanical vacuum gauge with a T connector. I searched on alot of places but I really cant decide which hose to connect the T in? I found a shabby picture of the exact car that I have. View image: bild I think that I should plug it in somewhere around the ECI MULTI but is there anyone who can say which line is correct? I dont want to break a fuel line or something! Thanks! Greetings from cold sweden! |
Green arrows show the way
The most reliable source of manifold vacuum is the brake booster hose. You will probably need to buy a tee that will adapt between sizes. Be sure to use clamps so you don't lose brake vacuum when you need it the most :eek: .
[IMG]http://i1102.photobucket.com/albums/.../bildarrow.jpg[/IMG] |
Usually any line that has a high vacuum at idle is good. As long as your show a vacuum at cruise that goes to zero at full throttle you probably can use the gauge as it is just a relative indicator of engine load.
The power brake line is a good source but I usually refrain from cutting into that line in the interest of brake reliability. Look for a line that goes into the intake manifold some place rather than into the air body. |
http://www.veloliner.com/images/lancervacuumline.jpg
This looks like a good place to Tee into. |
