Vacuum HP
I was driving home last night and noted that the absolute manifold pressure was between 7 and 9 psia, so I wondered how much horsepower that was. I Calculated it to be 36 HP! That's more than is needed to propel the car on level ground.
saturn sc1: 14.2-8 = 6.2 psi differential pressure 1905 liter displacement 4 stroke engine 2042 RPM at 65 mph Pv = pressure * volume/ time Pv = (6.2 * 4.448/.0254^3) * (1905/1000/4) * (2042/60) * 1.34/1000 = 36 hp units: Pv = (psi* N/lbf * m^3/in^3) * (L/m^3/intake strokes per revolution) * rpm/(min/s) = N *m/s N*m/s /1000*1.34 = hp 6.2 psid 1.905 liter displacment 2042.14153122327 rpm power, KW 27.2 HP vacuum 36.5 |
I think your equation has an error.
Small to mid size cars use 25-35 hp to cruise at 50 mph. Could it be your measurement was of the cars actual cruising hp with vacuum as a byproduct ? |
Show me the error.
According to the Aerodynamic & rolling resistance, power & MPG calculator here on the site, a 1998 SC1 uses just below 9 hp to maintain 50 mph.
Click here to see actual numbers |
where....... did this equation come from?
i'd like to think i'm pretty decent with math, but how you're calculating HP is entirely new to me. is it accounting for BSFC? volumetric efficiency? airmass? it LOOKS like the equation only accounts for displacement, RPM and MAP, which will not produce accurate results. |
It came from first principals. power = force times velocity
Show me a better formula. |
I'm no where near good enough in math to figure this one out other than to say that there is no way there is 36 hp worth of pumping loss.
I think that the actual formula would use vacuum and the cross section of the throttle opening, which is where the vacuum is being generated. If I had to pull a number out of my ass, I would guess than pumping loss for a saturn being driven at 60 mph on level ground with a constant throttle opening, is somewhere around 5-10 hp. Likely closer to 5. There are all sorts of smartypants on this board that know this kinda stuff backwards. i am sure one will chime in soon with a proper answer. This topic does bring up the idea (again!) of using some sort of turbine as a throttle for constant power O/P like cruising on the highway. |
I'm not sure you can calculate HP that way, but if you can, I think you've got too many intake strokes per rev. For a 4 cylinder 4 stroke engine you should have 2 intake strokes per rev (intake only occurs every other rev on a 4 stroke engine: intake and compression on one rev, power and exhaust on the next rev).
I have an old SAE paper on engine friction laying around somewhere. My recollection is that throttling losses are the largest single source of efficiency loss / friction at part throttle. That's because the pressure drop is small at wide open throttle, and the flow rate is small at idle.
My thermodynamics (AKA thermogoddamics) is pretty rusty, but I think the correct equation has a natural log of the pressure ratio in it. Or something like that. And I'm not interested enough to look it up. |
Humm, intake, compression, power, exhaust, that's two revolutions, one intake stroke. Piston is working agaist the vacuum 1/4 of the time, doesn't matter how many cylinders.
Or, you can just skip the intake stroke calc and divide the engine displacement by 2 since that is the volume the intake manifold pressure is seeing each revolution. Remember, the displacement of the engine is calculated by determining the volume of one cylinder (piston top dead center to piston bottom dead center), ignoring whether the design is 4 stroke or 2 stroke, then multiplying the volume of that one cylinder times the number of cylinders. So if you have a 2 liter 4 stroke engine it only pulls in 1 liter of air per revolution (a 2 stroke would pull in 2 liters, which is why they usually have a higher power density). |
for you to be making 36HP..... assuming a BSFC of .5, then you would be consuming fuel at a rate of 18 lb of gasoline per hour. that's almost 3GPH. at 60MPH, that's 20MPG.
you CANNOT calculate horsepower from that kind of equation. there are way too many variables that are missing, some of which you can't really measure outside of a dyno either. |
You need to take into account the energy regained on the compression stroke, even if we assume constant pressure and all to make things simpler.
2042rpm is 2042/60=34.03 revolutions per second. The engine draws in half its rated displacement per revolution, so this is 1.905L * 17.01 (let's just drop the thousandths) = 32.3L/second. The intake stroke consumes 32.3L*42.8kPa=1382 J per second, or 1.85hp. I don't know where your 36hp is coming from. To sweeten the deal, the compression stroke now regains some of that power, probably around 40% of it. So the total loss is about 1hp. Seems about right for a 1.9L engine that runs at those speeds. BMW only saw 10% improvement in fuel economy on naturally aspirated engines with Valvetronic, the throttle is not as evil as some people make it out to be. |
1905 cc = 114.3 cu. in. Start with your formula: Pv = pressure * volume/ time 6.2 psi * 114.3 cu. in./2 (this 2 is based on my previous assertion that you only have one intake stroke per 2 revolutions so you have to divide the displacement by 2) * 2042/60 = 12059 in-lbs/sec. 12059/12 (inches in one foot) = 1004.9 ft-lbs/sec. 1004.9/550 (ft-lbs/sec in 1 HP) = 1.83 HP. So the "vacuum horsepower" is only 1.83. I think this is measuring (if it's really measuring anything) the pumping loss of actually getting the air into the engine, not the engine output. Remember the pressure in the engine on the power stroke is much higher than 6 psi. Please point out if I made any mistakes in the equations - I've had a lot of interruptions while I wrote this. |
1.8 hp makes more sense, since when coasting in gear it doesn't make hardly any difference of the throttle is open or closed. I see the error, pressure should be divided by m^2 not m^3... that would make it 1.8 hp, if I divide the displacement by 2. Anyway the engine is operating between 1/2 and 2/3 maximum BMEP at 2042 RPM at 65 mph and a 15 mph headwind, probably a good point on the BSFC map.
i dont know if this is correct but i also came up with 1.83 hp using a lazier method
an online calculator at On-Line Fan Calculation under FAN APPLICATION FORMULAS to figure Fan Brake Horsepower Flowrate (CFM): i entered 70 -roughly 2000liters per minute Static Pressure at Discharge (in. Water): i entered 166 -roughly 6psi Static Fan Efficiency (%): i entered 100 and it spit out 1.83hp but that 1.83 hp on the table is why people can see gains with hot air intakes |
So 1.8 horsepower wasted you are never going to be able to harnes or delete.
Thats close to what it takes to run power steering or a thermal clutch radaitor fan when its "free wheeling". That isobaric part of the otto cycle really sucks. |
...it's WORK sucking air into the engine (through carburetter past throttle plate), which takes ENERGY and thus POWER.
HP = D * RPM * Pm * (k / k - 1) / (12 * 2) * ((Pa / Pm) ^ (k - 1 / k) - 1) * (1 / 33000) Where D is displacement in cu in. Pa is 1 atm, 14.7 psi. Pm is the manifold pressure k is 1.41 for air (adiabatic index or ratio of specific heats) divide by 12 to change inches to feet, divide by 2 because 4 stroke, and 1 HP = 33,000 ft-lbs/minute Using this example (114.3 cid, 2042 rpm, 6.2 psi map) the result is 1.8 hp, which shows your (Patrick) formula was good enough, and this post was superfluous. -mort |
On the bright side though, engine and drivetrain friction is probably eating up something like 3-4hp on the highway, so 1hp isn't all that bad in a way. |
