Value in incorporating solar panels in a mobile phone?
So a pretty common problem now with phones is the battery.
And people love to customize and make unique phones. Could it be of value to add (OEM) solar panels to a phone? Looking at this image of the front of the phone, a Moto X, we see quite a bit of bezel. http://ei.marketwatch.com/Multimedia...e-002128040cf6 Now it wouldn't be much, but it would add power while on it's back. A bigger opportunity if we flip it over. I posted that image because it shows the multiple options for backs. I do enjoy my Bamboo back http://i.imgur.com/M8JZndn.jpg BUT, what if this could be a solar panel? Since I just bought a solar panel, with a claimed 30,000 MAH storage (they later admitted 10,000-15,000, and it is ACTUALLY closer to 5,000) for about 17 dollars. That is all the parts and pieces, being built in an underdeveloped world, and shipped in bulk through a wholesaler, then shipped out to me, and paying lots of people along the way. They still made money off of me at $17. So the price isn't a big deal. Incorporating it into a device can't be too difficult. Could this provide much battery? True it won't be much in power, but while in a car with GPS/roaming, in the day there is more light to slow the drain. When it's sitting out with some light, it can still be gaining some charge. True not much, but would it be worth while? As much as I love adding wood to something technologically advanced (my phone, my car lol), I'd rather add something of actual value. What are your thoughts? Any rough calculations? We've got quite a bit of brilliance here, if anyone has any calculations at the value of this. |
Thank you for posting examples of what I have, specifically the old technology. Refreshing the topic early on- is there value in incorporating this with the device itself?
the back of the iphone should be a solar panel , so its always charging , even with just the office lighting many people sit in.
Patent the idea or see if it is patented. |
But per Google, the iPhone 5S has a max battey capacity of 5966 mWh. so unless my math's off (which it easily could be), it'd take about 15,000 hours to recharge a phone from office lighting. |
As James points out, solar panels on phones is useless.
I have a solar battery charger / LiPo combo designed to recharge a phone. The LiPo battery is 2Ah and can deliver 1 full charge to a phone. Positioning the solar panel in the best direction I can, it takes an entire sunny day to charge the battery. The panel has a surface area about 4x that of a typical phone. Yesterday I left my phone outside in the sun while I dug for a broken water main. 30min later I went to my phone to check the time, and it had shut off due to the temperature being too high. Leaving phones in the sun is not good for them. Phones don't need quad core processors. If people didn't expect their phones to be as speedy as their PCs, the battery could last much longer. |
I am certainly not gong to defend it against all the critics.
I think its a good idea, it can keep a phone ready for use if sits turned off most of the time. |
not enough surface area AND it encourages folks to leave their rather expensive toys laying about.
If I had solar panels on a smart phone, I'd use it to run a liquid cooling system for that big twenty jillion gigahertz giga-octo-core processor it needs to run the latest edition of Flappy Bird. |
Tablets have a lot more real estate. |
Heat's a factor I considered, but I have never had the X or the G overheat.
I imagine the exterior could get hot if in direct sunlight for a while. I see the issues in it, I still think it would be of value to incorporate small panels. Between the minimal cost, and over the life of the phone (for people who don't upgrade every six months), it would be worthwhile. James, I like the numbers. I know there are some people here who know them. It's not hard to research it, but KNOWING what it means in real life takes more than an internet search- so thank you, sir. |
Ive had a few solar cases and battery packs. Its my experience they need direct sun light from an untinted plate glass window to charge. I imagine one can build the solar panel to be worth while in office lights or sun light thats been filtered through a triple pane, bullet proof, etc office window it could at least negate standby if not maintain the current power draw.
My garbage junk from China for $17 dollars ( I complained about the lies in capacity, and they refunded me $11, so now it's $6) seems to always be drawing power. Although I leave it in my car, when I had it inside it still seemed to be charging whenever it was remotely near a window.
Guys, keep in mind I don't mean for this to be the only way it charges, or for it to be a huge breakthrough to revolutionize the phone industry. I just think this would be a good use of resources. Not great, but we could bring some power back to the phone while just being out. I'd much rather have this then a heart rate monitor. I have fingers and a pulse, I don't need that junk. Scanning my finger to unlock my phone? No thanks. I have a passcode, and GPS enabled and tracked incase it ever disappears. Not needed. |
Yea, it was silly of me to assume a solar charger with a claimed 30000mah capacity would be some large external device, and instead of just saying, "why not a case?" To just throw out a link, and assume it was about something you wanted to try have yourself, in addition to what oems could try.
To actually address the question though, I think for most users the space taken by a solar charger would be better spent on a slightly larger battery |
My point wasn't so much that solar on phones would be useless, as that there isn't enough energy in ambient indoor lighting to really charge much of anything. Most people don't appreciate the fact that the eye has a very nonlinear response to light: indoor lighting may appear about the same as sunlight to you, but in reality the sunlight is maybe 100 times as intense. Lux - Wikipedia, the free encyclopedia
Now if you're out camping, say, and leave your phone out in the sun, then solar would be useful. But how many people do that? Most keep their phone in a pocket or purse most of the time, and even if left on a table or desk indoors, the charging would be miniscule. Much more cost-effective to have separate solar chargers (which could charge/run any USB-powered device) for those who need such things. |
+! I have solar panels and toys in my window. Its creepy at times how the solar toys can slow or even stop when it still appears sunny out. Ive also had situations right before sunset where they perk back to life. I dont see anything different, but Ive assumed its a different wave length or something.
Hell, Ive spent a few hours laying under my solar array with a vom just taking readings and notes. Same thing, the poly crystal cells behaved one way while the monocrystals behaved another. If you want to use ambient light to extend the run time of your phone you need to measure the light and design the solar array after it. Quote:
Using solar indoors is only worthwhile for calculators that need minuscule amounts of power to run. A solar panel covering the entire back side of a smart phone and "charged" indoors all day might give it 10 seconds of extra run time. There is no way you could even approach maintaining charge on a phone that is on, but idle. Here's the math for my office: 30 fluorescent x 28 watt bulbs = 1008 watt 40ft x 36ft = 1440 sq/ft room 1008w / 1440 sq/ft = 0.7w per square foot Fluorescent energy to light efficiency is 11% at the high end 0.7w/sq/ft x 0.11 light efficiency factor = 0.077 watts of light per square foot Solar efficiency is 30% at the high end 0.077 w/sq/ft x 0.3 solar efficiency factor = 0.0231 watts of power per square foot of solar panel iPhone back side area = 0.087 sq/ft 0.087 sq/ft x 0.0231 w/sq/ft = 0.002 watts total solar power If I turned all the lights on in my office and the back side of my iPhone was entirely covered with the most efficient solar cells available, I would be lucky to get 0.002 watts of power. My iPhone has a 5.3 watt/hr battery. Lets generously say that at full charge, it can sit 48 hours before the battery is dead. 5.3 Wh / 48 = 0.11 Wh consumed per hour. 0.002 watts of solar power divided by 0.11 watts demanded by phone = 1.8% of the total power used by my phone on, but sitting idle. Maybe your office is brighter than mine. ;) |
And that's assuming the phone or tablet is face down. Most of my coworkers have it face up. :eek:
I guess laying the charger/case face down on your dash board or window sill if you happen to have a window seat? Now an office I use to work in we had to keep the blinds below the pelvis for fear of snipers. :eek: |
