variable exhaust?
What kind of results can I expect from putting a variable exhaust on my vehicle?
...variable what?
• pipe = length, diameter, temperature? • valve = lift, diameter, timing? |
hes talking about variable exhaust valve that sits in the exhaust pipe
(most are butterfly valves like your throttle body butterfly valve) it closes the butterfly vavle at low cruizing loads to improve low end response (as you now have more back pressure so gasses escape easier compared to a bigger exhaust) then it opens as load increases (like w.o.t) all this is controlled either by your ecu or by engine vacuum as for an increase in fuel economy well i wouldnt know but if you ask me you could invest your money in something abit more worthwhile, like a "economy grind camshaft" or a some intake mods and stripping emissions devices to increase fuel economy. do a google search and some reading on it and report back as you have me interested on if this might do something or not (if it does then i'm moving upto a bigger exhaust hahahaha |
sorry ment higher velocity |
So you are going to have more then one exhaust pipe?
Smaller exhaust pipe is not used for more back pressure, it's used for greater scavenging, back pressure is caused by blockage, you don't want blockage, you want your exhaust to use the pulses to your advantage because exhaust is not exiting as a steady flow. |
I cringe whenever I hear talk about exhaust backpressure.
...there are TWO determinants happening in exhaust "tuning":
• SONIC (acoustive) velocity (1100 to 1700 fps) which is temperature dependent. • MASS (gas slug) velocity (up to 300 fps) which is pipe cross-sectional area dependent. ...one is 'why' headers are sometimes wrapped to hold-in heat, and the other is 'why' headers use different diameters and lengths. |
Sonic Velocity is why headers are wrapped and Mass Velocity is why tubing is sized, right?
From my weak knowledge, the diameter of the tubing determines the torque range based on the engine configuration. I can't help with the variable exhaust but I do know of a variable intake design. Ford uses a second set of throttle bodies in their engines to improve the low end air velocity for better low end torque. I've personally seen them in the 3.8 liter V6 in the Ford Windstar where they were located one in each intake just before the fuel injectors. But I know they also used them in the Ford Ranger at some point. The switch to full open was in the 2k-3k RPM range. Sorry that I can't be of any help. |
If this really worked, every car would already have it. |
they are on most new cars
honda uses them toyota uses them some motorbike have them some mitsibushi's use them (vaguly recalling this one i could be wrong) it mainly an emissions device but it does increase fuel economy as for how much i don't know :) |
...presently, you find more INTAKE systems using "tuning" techniques than EXHAUST systesms, mostly due to the HEAT problems, but it *is* possible.
...a "mechanical" example of EXHAUST tuning are the 2-stroke muffers which are specifically designed to certain engine speeds--raise the low-end torque and high-end power at an acceptable loss of mid-range. |
