Various Plastics - Research Thread
Lots of information and familiarity in the forum on Coroplast (brand name for corrugated polypropylene often called "sign board") and ABS plastic. However I've stumbled across something which may expand our bag of tricks a little.
Proteus+Quadrant+polypropylene 928 Motorsports LLC Bonneville Preparation, 2013 https://plus.google.com/101297578708891518020/posts http://forums.pelicanparts.com/uploa...1371263075.jpg Quote:
https://lh6.googleusercontent.com/-J...2012%2B241.JPG That is an awful lot of support behind that plastic sheet material. Maybe more work than it's worth? Another product line from Quadrant which caught my attention is below. Lightweight construction components (LWRT) SymaLITE, 3D molding, low pressure pressing, construction, undershields, corrosion resistant, wear resistant, covers, noise absorption, protection, thermoforming, one-step molding, high resistance, part integration, handling - Quadrant Quote:
http://www.quadrantplastics.com/typo...0d8ddfb50e.png http://www.quadrantplastics.com/typo...dbfea013fd.png Maybe with all the heat under a car, metals might still be best. Not sure, as I've never done a belly pan. The HDPE plastic (High-density polyethylene) chin spoiler I put on my truck, only lasted 3-years (now held together with foil tape). Mostly because people kept backing up into it, but also major UV fatigue and brittleness is evident. http://www.mastermark.com/product_de...ct_group_id=56 http://www.mastermark.com/images/product/56.jpg Quote:
Found some new information, something called Kydex.
Belly pans - Pelican Parts Technical BBS Quote:
I saw that material when I found my ABS sheets. Mine were $32.08 shipped. I hardly know anything about ABS, but absolutely nothing about Kydex. It does sound interesting, though.
This is what I ordered: Amazon.com: 24"x48"x1/16" ABS PLASTIC SHEET CUSTOM STEREO TEXTURED FRONT SMOOTH BACK: Office Products |
I think the ridgidity of ACM would be awesome on belly pans and it can be rolled bent etc quite easy.
ACM SIGN PANEL FEATURES Light Weight Rigid and Durable Accepts Vinyl Graphics Excellent Outdoor Weatherability Stock Sizes - 48 x 96; 48x 120 60 x 96 & 60 x 120 Custom Colors & Finishes High Strength Easily Fabricated Weather Resistant Accepts Screen and Digital Printing Available in 3MM & 6MM Thickness ACM Panels its cheap too did I mention that part. I will probbably build my chin spoiler and kam back from this. |
ATLANTA INTERNET SPECIAL ONLY
SIGN BOARD COMPOSITE PANELS 3MM .007 ECO 48" x 96" WHITE -- $37.00 3MM .008 LITE 48" x 96" WHITE - $41.00 24 GAUGE POLYESTER PAINTED WHITE/WHITE STEEL SHEETS 48" X 120" -- $40.00 MUST MENTION INTERNET SPECIAL TO RECEIVE SAVINGS! PRICES VALID THROUGH JUNE 30, 2013! CALL WRISCO ATLANTA 800-753-1066 This stuff is excellent if ya want to see it in use Most gas stations use it for outside walls example would be Texaco The silver sparkle exterior and red portions are ACM I had that job for 6 mos installing. its pure aluminum sheets with plastic resin core then painted. a bb gun puts dime size indent with pock in center but doesnt get through. I also plan to wainscot my Living room with it because I live in a flood zone in MS. this stuff is awesome. |
Do you have any idea how much shipping is? |
From the "ACM board much better than coroplast" thread
Grimco MaxMetal 3mm Grimco - Substrates: Max-Metal, MAX-metal Alumacorr Alumacorr vs. Poly-metal Poly-metal PolyMetal |
I always thought it was "chloroplast".
Im not a salesman.
There is an 800 number attached they will hook u up with a localized vender.
I maintain a heavy Industrial factory for a living myself. |
