04-29-2011, 01:58 AM
dude...wait...what?
veggie oil rx7
nope
82 rx7 diesel
82 300d diesel
84 b2200 diesel
All veggie, all the time!
The Following User Says Thank You to Odin For This Useful Post:
04-29-2011, 03:18 AM
Diesel Addict/No Cure
Very nice! What are you going to do as far as dealing with the final drive ratio in the rearend?
I'll make an early prediction: properly geared and driven, at least double what you have done with the rotary.
04-29-2011, 12:49 PM
Way cool. Yes, those rotaries had very low torque and numerically high final drive ratios, so you may have to gear it down to realize decent highway speeds and best mileage.
I'm not coasting, I'm shifting slowly.
04-29-2011, 12:58 PM
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Soooo... Id love to see someone make a rotary diesel. Just sayin'.
04-29-2011, 01:52 PM
Anyone out there make a rotary diesel small enough for a car or light truck app?
04-29-2011, 02:00 PM
Anyone make a rotary diesel at all?
Never heard of one, personally, but can't imagine it would be difficult to do. Two small DI injectors per rotor, right where the spark plugs should have never been put, with one for enrichment/boost and one for standard fueling.
Wouldn't have the diesel knock, would run much more smoothly, and rotary engines can handle big boost without coming apart.
IMO, they WERE a superior design. They had flaws, but so do piston engines.
For clarification, I'm referring to Wankel engines.
04-29-2011, 03:17 PM
The a addition of material to the rotors to up the compression can heal the apex sealing issue. More bulk of metal around the area that the seal rides in gives it (THE SEAL) less mechanical advantage over the rotor's edge.
IMHO, the biggest problem I know of is the rotor side seals and burning oil. Not so much of a problem in a diesel... Lol.
04-29-2011, 08:28 PM
Very cool! A friend of mine used to have an rx7 rotary turbo he will love this.
I run veg oil (rapeseed) usually 90-10with petrol or 50-50 with diesel. (mk 1 focus, 1.8 tddi) brilliant stuff
04-29-2011, 10:35 PM
#9 (permalink)
Same thing here... Limited by what I can find, build, afford... Diesels in the states go for a premium in some areas...
04-30-2011, 04:11 AM
#10 (permalink)
We are lucky to have diesels yeah. I picked my focus up in jan and I've done 3+k on veg since I switched a month ago. Great stuff! I hadnt planned that when buying the car - lucked out there. Most modern common rail diesels can't run this without heavy mods. My car just drinks it happily
As far as the scrappers - haven't been around recently, but there are always a pile of wrecked type-R civics and the usual boy racer numbers. Gross story; a friend saw one at a scrappy and jumped in the drivers seat to evaluate the cockpit - a fixer perhaps. There was blood and brain matter all over the dash :S obviously a nasty crash!!
