Very disappointing Dodge Journey mileage
:mad:
Well, the results are in... I went from a 2003 Chevy Venture Van, 3.4, auto 4 speed POC to a 2010 Dodge Journey, 3.5, auto 6 speed and LOST 3.1 MPG AAUUGGHH!!:eek: |
I think if I needed a van full time for work Id go for a sprinter van with the mercedes logo, diesel engine and such.
Maybe the tires are only inflated to 18 psi and you can fullem up? :thumbup: |
It's a 2010, so it's not likely unbroken-in.
On the other hand, I'd check what sort of lubrication is running in that motor... and the automatic... and check the tires... and... |
EPA 24 hwy? The key to getting better mpg- if that is what you want- is to select something that gets good mpgs.
Stay out of overdrive, if you're driving about in town. I go to "3" in both the Karen-mobile and my Caravan, and I drive in OD OFF with the truck.
