Old 12-14-2008, 01:56 PM   #1 (permalink)
Lil Sulf - '94 Toyota Corolla
90 day: 47.62 mpg (US)
1994 Toyota Corolla
After starting at CleanMPG and then clicking the links some of us have in forums sigs, I was introduced to ecomodder. What a day to remember.
Anyways, I've done even more stuff since I started this thread, and more stuff since I last updated it; and I'm sure it won't be the last.
Current list of mods:
Rear wheel skirts
Lower grill block
PS mirror delete
DS mirror delete(lastest addition as of this update)
Interior blind spot mirrors, both sides(see above)
Front tire spats
Partial undertrays in front and back
Smooth wheel covers in front
One smooth rear wheel, other doesn't have a hubcap.
Comments are free so dish em out!
And that's without a Scangauge o.O
Old 12-14-2008, 04:55 PM   #2 (permalink)
Covered the tire spats so there is no air getting in the "enclosed" part.
Old 12-14-2008, 05:12 PM   #3 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
I actually like the roughness of the text for cleanmpg and ecomodder done with tape and spray paint (presumably).
I'm doubtful of the rear tire spats, but time will tell. I think they should be closer to the tire and sturdier (think what will happen when it snows - you get that big iceberg there)
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 12-14-2008, 05:41 PM   #4 (permalink)
Snow, LOL!
I live in Florida.
Old 12-15-2008, 03:21 AM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Sulfuric -
Most egg-salad! I like the shape of the front wheel spats. The driver's side is the kind of curve I have always imagined, in tension with the vertical rear brace. I'm not sure why you showed a picture of the coolant(?) guage. What does it signify?
CarloSW2
American Solar Energy Society
Old 12-15-2008, 09:30 AM   #6 (permalink)
Added by accident.
But when I had my partial upper grill block, the cooling fan would turn on when the needle hit just over halfway. I mean 51/100 kind of halfway. Now that I took off the upper grill block i haven't had the problem but I need to test it more. Florida is not cold enough, even in winter, to for my old setup to be safe.
So that gauge there....that's coolant temp? i thought it was engine temp. Or is it basically the same thing, or same way to measure engine temp?
Old 12-15-2008, 10:41 AM   #7 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I like that last picture of the car under the teardrop arch. What have you got planned?
Old 12-15-2008, 12:49 PM   #8 (permalink)
...asjlklkgfboattailmdfkhbmaybexzdjaf...
Old 12-15-2008, 03:01 PM   #9 (permalink)
Coolant temp is often used as a proxy for engine temp, and is what most people refer to when they talk about "engine temp". The problem is that there is no one "engine temp"; different parts of it run at different temperatures. That's not too much of a concern for a modern car, as the coolant circulates pretty well and tends to keep most of the important bits right around their "proper" temperatures.
However, it may take your oil twice as long to get to "normal operating temperature" as it does your coolant. And the cylinder head(s) get significantly hotter in places than your coolant and oil ever will. And the exhaust? Waaaaaaay hotter. But those usually aren't that important to us.
So, uhh, yeah. "It's pretty much the same as far as you mean."
-soD
Old 12-15-2008, 04:08 PM   #10 (permalink)
Cool, thanks for the info.
Also, my GuessGaugeIII says that I'm at about 42mpg with a little over half a tank left.
Help with my aero mods: 1.8L 05 Auto Toyota Corolla blackjackel Aerodynamics 73 11-22-2011 09:55 PM
Disabling the compressor when using defrost on a Toyota Corolla BBsGarage DIY / How-to 11 02-28-2009 10:31 PM
Review: 2009 Toyota Corolla LE (37.9 MPG) RH77 General Efficiency Discussion 22 05-09-2008 04:55 PM
Addition of low profile rear spolier- Toyota Corolla TimboliahPantsOnFiyah Aerodynamics 2 04-22-2008 09:18 PM
Win an EM Sticker: guess Dad's mileage (Toyota Corolla automatic). Ends Jan 13. MetroMPG Hypermiling / EcoDriver's Ed 51 02-07-2008 09:02 AM
