Old 03-26-2008, 10:09 AM   #1 (permalink)
2005 CivicEX - '05 Honda Civic EX
90 day: 37.26 mpg (US)
05 Civic Grillblock?
I was curious about those that use grillblocks on their cars. Are you using them in the summer/hot weather as well? I live on the coast in GA and it gets quite hot. I'm looking at aerodynamic solutions for my car. just curious. Thanks,
Case
Old 03-26-2008, 10:37 AM   #2 (permalink)
Hi Case,
I've got some foam-pipe insulation on my '04 civic held in with duct tape.
Can't say that it has been a big help yet,
but I'm going for a coro-plas cover for the lower intake,
leaving the top open for summer cooling.
I live in New England so the cool air allowed me to cover both top and bottom right now.
But the summer will require more air.
Old 03-26-2008, 10:49 AM   #3 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 62.77 mpg (US)
I use mine year (it has just a thin slot opening) around here in upstate SC, even when the temps hit 100F. The only over heating problem I have had is when driving at over 70mph when temps are over 90F, but I plan to install a driver adjustable grill opening before the hot weather hits.
aerocivic.com
Old 03-26-2008, 11:01 AM   #4 (permalink)
Thanks guys. I might try to block the upper grill to start and see how it affects the engine temp & FE. Then try the bottom leaving the top open if the first trial goes well.
When I do the top grill block, I'm thinking of something temporary like cardboard to mount flush with the outside. The foam pipe looks nice though. If basjoos is able to get by with a thin opening in SC it should work for GA.
Thanks!
Old 03-26-2008, 12:46 PM   #5 (permalink)
personx's Avatar
I had read of someone who had a water sprayer (like one for the windshield) for their radiator in a tightly cowed aircraft with a auto engine. they needed it for the rare times that they were sitting on a hot ramp at a real busy airport in the middle of summer waiting their turn to takeoff. they would just hit the button every once in awhile to keep the temps in the good range. once they were airborne (moving) it was not needed or even at a normal airport.
Something like that might make a good backup for those extra hot days stuck in traffic.. I'm really going to give it some thought when I block mine.
Old 03-28-2008, 09:51 AM   #6 (permalink)
I've blocked the lower grill to start. I haven't taken long trips yet.; just light city driving and 15 mins of Hwy driving. Temp is a little higher than normal but nowhere near red. I'll know better after some longer city driving during midday. So far it's looking good!
Old 03-28-2008, 03:31 PM   #7 (permalink)
grilleblock
Mine are okay all year in Texas.The CRX did overheat at Bonneville.It was 85-degrees ambient temp. on the course,and the car was under full throttle for 6-miles until through the trap.Other than that,its alright for 4-seasons.I've tried to overheat the T-100,just doesn't happen.Modify slow,every car should be considered on a case-specific basis.
Old 03-28-2008, 05:28 PM   #8 (permalink)
EcoMudder
Harpo's Avatar
Harpo's Honda - '05 Honda Civic VP
90 day: 42.64 mpg (US)
Mine works well
Thanks!
http://forum.ecomodder.com/showthread.php?t=1405
I'm on to IAT mods now.
Old 04-17-2008, 11:51 AM   #9 (permalink)
I've tried both the upper and the lower grill block. The car temp runs the same with either one of them blocked. I've blocked up the front right now. I used cardboard for a week and now I've made one out of plexi.
Old 04-17-2008, 11:55 PM   #10 (permalink)
Danger Ranger - '01 Ford Ranger Edge 4x4
90 day: 14.52 mpg (US)
Moms car - '05 Ford Freestyle Limited
90 day: 21.92 mpg (US)
Mistress - '10 Harley-Davidson 883 Sportster 883 Iron
90 day: 42.53 mpg (US)
Send a message via AIM to meemooer
^^clean, nice install
Randy
OEM Grill Block for 92-95 Civic Owners TomO EcoModding Central 6 12-21-2014 09:58 PM
Any guesses on '83 Civic mpg? Ryland General Efficiency Discussion 10 10-19-2013 10:28 PM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 02:52 PM
Jalopnik hypermiles a diesel Civic & Audi Q7 SUV - much efficiency ensues! MetroMPG Hypermiling / EcoDriver's Ed 0 02-15-2008 12:53 PM
2004 Honda Civic Sandy Introductions 4 01-22-2008 11:57 AM
