I've drilled in mine alloy wheels made thread inside and screwed in my aluminium discs.
Here is a video of them on youtube http://www.youtube.com/watch?v=W1dwPQ37FlA |
holypaulie - I hope you don't mind I copied your vid post (from http://ecomodder.com/forum/showthrea...eels-7405.html) into this dedicated thread. It's threadworthy on its own!
You don't have a fuel log... what kind of fuel economy are you seeing? What difference from stock? |
Nice !!!
Please do let us know what kind of FE changes that you see ! Thanks for posting the video. I love what you have done with the car - great use of the hood vents. |
Pretty slick. I was definitely thinking about the front wheel well partial covers/extenders that you have on there. As long as the tire can turn, with suspension compression, they might as well be a mm away from the tire, right?
Hi Paul,
I really like what you've done, too! I'm envious of the color match you have, and your fabrication skills are commendable. I wonder how the front wheel skirts could be made from (slightly) flexible rubber/plastic? |
I'm with the others, the mods look great. Do you have any internal ducting for the cooling system?
Stock MPG City: 27 Hwy: 35 Present MPG City: 32-35 Hwy: 40-45 at 55-60 mph (hot summer 45-48 MPG) |
How do you have the rear skirts rigged up? Good stuff!
I've cut 1" wide, 1/16" thick and 2" long metal strips and bent them 90* on vise. Next drilled bracket directly to inner edge of wheel well with self-tapping screws. Painted and sealed with waterproof glue. Finally screwed in skirt again with self-tapping screws. There are 4 brackets to hold tight and safe wheel skirt. |
Have you considered adding a small duck-tail spoiler to reattach the flow on the back of the car ?
I notice the hybrid has a small duck-tail spoiler. Perhaps some tuft testing would be useful. |
There's really not much else you could do without significantly more radical modifications; perhaps the rest of the underside could be smoothed over. Very clean work, I like it better than stock. I'm inspired to try this on my car. Have you tuft-tested your hood vents to see if they work the way they should?
