Vilsack: US Should boost Ethanol use
The Associated Press: Vilsack: US should boost ethanol blend in gasoline
It sounds good to me.
Is this an attempt to stabilize the price of corn?
What a crock. Mandated use as well as price subsidies! It's time to ditch the subsidy, and steer clear of too much corn-based fuel. Clean water is just as valuable as oil. Using precious water to grow corn for fuel makes no sense. Algae bio-diesel I can get behind, but this is just an Iowa good 'ol boy giving a kick-back to the home state.
Now i was just about to post a thread about this until i ran across this one. I've talked to alot of muscle car guys and heard from a few of you guys on here that With E85 as long as you advance your timing to work with it right it helps your car and runs stronger. I'm stoked about the 15 percent ethanol since my family owns older cars. As long as the timing is stepped up on the cars to work with it there should be no problems with this right?
