Virtual Boattail 0n 05 Honda Civic
It's been in the mid 80's quite bit, so I've been cranking the fan in my car, with the AC off. I decided to put all that air to work and vent it out the back of my Civic LX trunk's low pressure area.
I took out the lights from above the license plate and mounted them an inch higher. That way the light still shines out, but there are two large openings. When the fan is cranked up, the air pours out of the holes. It's pretty impressive. I don't expect the have huge FE improvements, but I know it will help. I'm also aware of the danger of exhaust coming into the cabin if I don't have positive interior pressure. I'll run some tests late tonight if I can get a nap in. Again, I suspect the difference will be hard to measure. |
One Way Valve
You may be able to buy (or make) a one way valve so air goes out, but not back in. You should be able to make it work without a problem. Like you say, the results should be minuscule, but I like your thinking.
Blow on your hand as hard as you can. It's just a little weaker than that, but with more volume because of the size of the holes - each about the size of a half dollar coin. |
Let A equal 1, which is at least order of magnitude for a passenger car. The diameter of a half dollar coin is, um, 5 cm(?), which is .05m. Area of each coin is pi * .05 * .05 / 4 ~= (3 * 2.5 / 4) *10^4 ~= .0002 m^2. You have two such holes, so .0004 m^2. See where this is going? To completely negate the drag pressure the outgoing pressure would have to 10000/4 = 2500 inches of H20. Assume your car fan is really powerful and you have 10 inches of H20 pressure difference (this is pretty doubtful), at most you negate 1/250th of the drag. |
Detector?
So here are your first two questions, which I answered before you asked them: 1. What keeps the fumes out? 2. Will it make a measureable difference? Yes, it will keep the fumes out (see first post). You would have to keep the fan on. And yes, it can be measured, but I probably won't get enough samples to capture the difference (see first post), so it won't be measurable thereby. Logic tells us that it will make a difference. A lot of small differences can make a big difference. |
I'm surprised that modern cars and trucks don't have a CO detector by now... :(;)
Anyone wanna loan me their parakeet?
I finished the experiment, and I must say I'm pretty excited. I did 6 runs from Hartland (H) to Oconomowoc (O), WI on Hwy 16. I had originally planed an additional 6 runs which would have been on the return trip from O to H, but the cops pulled me over on the return route the first time, so I abandoned that aspect of the testing because they were all over me on each return trip.
Here are the results in the order in which they occurred in A-B-A-B-A-B pattern, where "A" is a test with the fan turned up to its highest setting and the two light holes open and "B" is a test with the fan turned up to its highest setting and the two light holes covered up with tape. Results: A1: 50.3 mpg B1: 49.6 A2: 50:1 B2: 50:0 A3: 50:2 B3: 49:9 A couple of notes:. The stats on the Scanguage were reset at the same specific points (road signs) at the beginning of each run. Resulting stats were recorded at the same specific points (road signs) at the end of each run. The car was up to speed (50 mph each time) and set on cruise at least a quarter of a mile before the beginning of each run. On the "B" runs the taped holes were checked to make sure they were still covered at the end of each run. This experiment took place between 1:30 AM and 4:00 AM CST. I stayed in the right lane at all times, except where the road narrowed to one lane, due to construction. I kept the radio off and did not use the wipers, so the headlights and the fan were the only devices I had on. The engine fan was running quite a bit throughout the test. It was a variable that I could not control. Normally I would turn the heat up just a bit to reduce the water temperature, but I couldn't do it because I was testing. However, I do want to add that under normal conditions turning the heat on just a little keeps the water temp below 206 degrees, where the fan normally turns on. And with that much air flowing, the temp change in the cabin is hardly noticeable. Weather: The road was totally dry. UV Index: 0 Low Wind: From WSW at 5 mph Humidity: 95% Pressure: 29.89 in. Dew Point: 68°F Visibility: 9.0 miles Final comments: I may do more experiments once the guilt of wasting all that gas and ruining by mileage by driving without hypermiling wears off. I'm looking forward to others trying this out. |
One more thing: I drove each return trip from the end of each test to the beginning of the next test with the fans off. I didn't smell anything, which is what I expected. If the high pressure is in the front of the car and the low pressure is in the back, the air will tend to flow to the back of the car and out the holes. Of course, the car isn't always moving, so that is always a concern - hence the fans staying on.
I wouldn't worry about CO much. First off it takes a lot of it to do damage, and second is that modern cars emit very little of it. Carbed cars were a lot worse. You'd get a killer headache before anything happened.
1. The data is limited. The means differ by .37 mpg but that is not much different than the variation within the measurements, so we can't say with much confidence yet if it the measured difference is statistically significant. 2. You knew the state of the car for each test, which opens up the possibility of subconscious changes in driving style which could bias the results. If you do repeat the experiment it would be good if you could have somebody else flip a coin before each run and then open or close holes without telling you which they did. You can determine which it was at the end of the run. I'm still skeptical - it doesn't seem right that the tiny amount of air coming out of those two small holes could significantly affect the large and continuously generated volume of low pressure air behind the car. |
I did think of another possibility. When the cabin is sealed the fan is pushing air into a closed space so the internal pressure of the car goes up. When you unplug the two back holes you reduce the cabin pressure by some amount, and the fan doesn't have to work as hard to move air into the cabin. So it draws less current, so the alternator is on less to provide that current, so the MPG goes up slightly compared to the "fan on, holes closed" case because the engine is loaded less. This may actually be a a gas saving technique (albeit a small one) via a mechanism that has nothing to do with the car's aerodynamics. If this hypothesis is correct plugging the back holes and slightly cracking a back window should give some FE improvement too. We've all seen the A/C versus windows open arguments, but I do not recall anybody measuring fan +/- windows open. |
Frankly, in these situations blind studies aren't done. Popular Mechanics, Consumer Reports, Car and Driver don't do blind studies. They do easily replicable tests and publish their results for people to judge and peers to examine, and possibly retest. However, if you do have the resources, please test it yourself. Keep in mind that a proper scientific test requires a random sampling of the available population (meaning both cars and drivers). If you can also get a dust-free wind tunnel, then that's even better. Keep us updated on your progress. |
