EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   vortex generators at rear bumper?? (https://ecomodder.com/forum/showthread.php/vortex-generators-rear-bumper-4070.html)
crexcrex 07-26-2008 05:08 AM
Obviously the question of vortex generators may have reached the stage of overkill, i however have a question that came up today as the result of having seen two newer Honda's with vortex generators at the rear bumper.
I am talling BIG vortex Generators at least four accross the bottom of the rear bumper cover..................i would appreciate any one knowing something about the Honda vg's which are stock, built right into the bumper, Would someone please enlighten me re the built in VG'S?
thanks
Daox 07-26-2008 08:15 AM
Got any pictures?
MetroMPG 07-26-2008 12:20 PM
VG's won't work in turbulent flow. There's no chance the flow under the rear of the car is anything but turbulent unless you've got a full, smooth belly pan, (and even then I think it's probably doubtful what with tire interference).
azraelswrd 07-26-2008 03:24 PM
Only 4 on the bottom of the rear? Is that really enough to do anything significant?
markweatherill 07-27-2008 03:35 AM
I reckon these are just styling devices. The 'rugged' look of skid plates with strengthening ribs is appearing front and back and even on the side of some vehicles.
meemooer 07-28-2008 12:05 AM
newer honda's? Pretty sure the SI's come with those, and probably the Si Meugan's. I'll take a look at hondas lineup at work and tell you guys tomorrow night
crexcrex 07-28-2008 12:36 AM
Thanks for taking the time to check it out, might be interested to know that vette has gone the same route i think the rear bumper covers are close to a grand..............could be all of the after market guys are reading ecomodders and plan on making a profit from our ideas and experimentation,,,,,,,,,,My thoughts
meemooer 07-29-2008 10:44 PM
yeah i only saw it on the back of the SI mugen's. It has 3 air splitters on the rear and the exhaust is where number 4 would be. 33K and it gets the worst of civic gas mileage. and it is slower in the 1/4mi then the regular SI too
crexcrex 07-30-2008 02:42 AM
I for one appreciate yor checking out the Honda's with the Vortex Generators as it is one modification that obviously is all show and no go. They sure look pretty like the ex gal friend, pretty expensive, no loss as i reduced the cars weight by 120 pounds.
justpassntime 07-30-2008 04:22 AM
Are they VG's or defuser pan?
But unlike the VG's the 120 lb loss made for a quieter ride!
crexcrex 07-30-2008 04:53 AM
Meemooer can probably tell you if it is a diffuser pan or simply vg's. I personally suspect that they are vg's..............the diffuser pan applies downforce and does away with spoilers and down force, i was previously informed down force does not make for ecomodding.............lets hope that meemooer is reading this and can correct us both.
I do know that i have seen vettes with those expensive addons and they were indeed pan diffusers. Pretty pricey stuff might as well put lead into the trunk.
crexcrex 07-30-2008 05:07 AM
vg's noiseless
The 120 pound loss and fuel gain over rides a ex gal friend who can't sing and makes vg's pleasant to hear............the other is people staring at the vg's and trying to figure out what it is at least a newbie ecomodder will ask questions, my response is let them eat gas!
aerohead 08-20-2008 03:01 PM
VGs
thanks
Are they really VGs,or could they just be some styling gimmick.Even in aviation,where VGs originated,they were never applied to a trailing surface,as there's nothing back there to re-attach to,which is the purpose of a VG leading a flap or aileron, at very high angle of attack.I think,since Soichiro died,HONDA has lost some of it's compass.
crexcrex 08-20-2008 05:21 PM
Angle of attack? i think you have forgotten it is the angle of departure, i am not flying a delta winged aircraft...........at the speed i drive this is one car that would never build up enough speed to take off.
I could probably read the guy at the bus stop newspaper at the snails pace that the rex travels
aerohead 08-22-2008 05:11 PM
angle
My thought was,that on say a commercial airliner,on glide slope for landing,and slotted flaps,extended fully and lowered completely,that the turbulators near the rear off the wing,help the flow to re-attach onto the flap,which is at its highest angle of attack (and in stall for it not for the turbulator) to generate safe low speed lift,albeit with tremendous drag.------------------------------- Is that a Subaru Rex that you're driving?
