EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   VSS limit (https://ecomodder.com/forum/showthread.php/vss-limit-29787.html)
alexander.foti 08-20-2014 03:59 AM
VSS limit
Hi all
I have tapped into the VSS signal from the clocks on my NC700.
I have my pulses per mile set to 120000. If I set my vss delay to 2ms it reads up to 10mph only.
1ms reads up to 38 mph only.
0ms reads up to 78mph, after that speed it starts going down until it reaches 0.
The bike has a VSS which is a hall effect sensor.
Any ideas? I would really hate to have to add a reed switch and magnet as its very messy on the bike :(
Thanks in advance!
alexander.foti 08-20-2014 11:30 AM
Just had a longer ride today, after a quick tweak half way through, the mileage tracking is spot on with the clocks which is great!
I have to have my VSS delay set to 0ms otherwise it isnt accurate (as per my prev post).
I had a thought, my VSS pulse is 0-5v and is being generated by a hall effect sensor in the gearbox. I would be very suprised if my inability to detect above 78mph is due to signal noise, but instead due to the voltage?
If I can generate 0-12v instead of 0-5v from the clocks, does anyone know if it will get any better?
alexander.foti 08-20-2014 02:49 PM
If it is an issue of too many pulses, I am thinking of using a pulse divider with a CD4027 and powered by a 5v regulator:
http://i1057.photobucket.com/albums/...psd082f1e7.jpg
pin 3 will be from the VSS sensor on the bike rather than the "ignition coil" like in that diagram.
P-hack 08-20-2014 04:56 PM
that is a lot of pulses, given the delay changes the top speed then that seems like the problem. A dedicated atmega chip might be able to keep up with it, but not one that is monitoring injectors and displaying data on an lcd and keeping running 64 bit tallies. I would divide by 24, that is every time the vss edge changes 24 times, toggle the output pin, set pulses to a sane 5000/mi. Lunch off the existing 5v supply and intercept the vss, no oscillator required if vss is interrupt driven. @ 8mhz you have about 3000 cpu cycles to sort each edge out @ 78mph.
Or use a gear sensor and some ferrous screws on a wheel.
alexander.foti 08-20-2014 04:59 PM
I would say thats the issue as well, although I would like somebody who is experienced with the code to let me know if it is.
Surely I can just use a freq divider on the VSS signal to keep it seperate from the mpguino? Im no good with IDE like the arduino, and OK with electronics (if following instructions :) )
meelis11 08-21-2014 03:49 AM
Hi,
check my topic, I had speed jumping problem and I added capacitor to all my boards to smooth out speed-jumping
http://ecomodder.com/forum/showthrea...5-a-21984.html
Maybe you could try to remove that capacitor near input pins and resistors - it has 103 written to it. Probably you have so many pulses (normally pulses/mile is between 4000 and 10000) that capacitor is smoothing pulses to steady voltage.
Meelis
alexander.foti 08-21-2014 03:57 AM
Hmm yes I see what you mean, it is a lot of pulses compared to everybody else.
I have already implemented the device into a watertight housing. I would have to destroy the case to get back to the pcb (stupid I know!).
Do you think dividing the pulses before it enters would also solve the problem?
meelis11 08-21-2014 04:50 AM
Probably dividing pulses works, but removing one capacitor may work too, maybe not. But I understand if you dont want to destroy your enclosure. So if you laready have parts to make pulse divider then you could try it.
Can you post pics? would be nice to see how you made watertight enclosure.
alexander.foti 08-21-2014 04:51 AM
Of course, when this is all finished, I will do a whole write up with pictures, in case anybody else wants to do the same install on a NC700 :)
alexander.foti 08-21-2014 10:08 AM
Have come up with the following:
http://fotifixes.com/imagehosting/im...withcap_v4.png
Lets see if it works. This should divide the pulses by 16.
t vago 08-21-2014 01:36 PM
With 120,000 pulses per mile, and going 78 MPH, your MPGuino is seeing a pulse about every 385 microseconds. That's about the time needed for the MPGuino hardware to respond to the interrupt request caused by the VSS pulse; and for MPGuino to execute the ISR for it, and return to the main display routine. If you go faster than 78 MPH at this point, the MPGuino will receive a second pulse as it is trying to process the first pulse, and the MPGuino will simply ignore the second pulse. 385 microseconds corresponds to 2600 Hz, which appears to be the VSS sampling cutoff frequency for the MPGuino.
The addition of a vss debounce of 1 ms is going to trash that VSS pulse length.
You're on the correct path. Putting a divide-by-16 circuit will drop down the VSS pulse frequency to something that MPGuino will handle.
alexander.foti 08-21-2014 01:41 PM
Thanks t-vago
Its nice to know that my random thoughts are backed up by some numbers from inside the mpguino brain.
That circuit I posted, should divide by 16 and give me approximate 7500 pulses per mile! :)
Not quite sure why my bike has so many pulses per mile.
P-hack 08-24-2014 12:13 PM
sounds like an abs sensor (high resolution). Is there another vss on the bike (how does the speedo work?)
alexander.foti 08-24-2014 12:24 PM
It's the speed sensor from the gearbox that drives the speedometer that I have tapped into. I avoided the abs sensors on purpose. Honda motorbike vss's are very high resolution. My xl125 had a similar high number but couldn't go past 75, so was never an issue.
P-hack 08-24-2014 01:44 PM
interesting, fyi I don't reach for discrete chips much anymore, since the micro-controllers are so cheap and I have a better chance of debugging them.
There is a standard arduino example in Arduino - ButtonStateChange
remove all the serial crap, modify it to divide by 24 instead of 4, and use the led pin as the output to the mpguino vss input.
If you have an uno, you can use it to program one of these (atmega w/uno bootloader, $1.98):
New ATMEGA328P PU with Arduino Uno Bootloader ATMEL Free Shipping from USA 2014 | eBay
and get the size down to one chip. I don't know much about flip flops, except that they leave me with a soft forehead.
alexander.foti 08-24-2014 02:25 PM
I have zero Arduion experience :( I think I would have to look at a arduino traning guides or something to get me going, I suppose I could have done that instead.
It costs about the same in parts I suppose.
