EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Vuilleumier cycle heat pump (https://ecomodder.com/forum/showthread.php/vuilleumier-cycle-heat-pump-19477.html)
jakobnev 11-14-2011 06:20 PM
The Solar-AC FAQ: Vuilleumier cycle (similar to duplex Stirling)
It uses heat, not mechanical energy, to do the work.
ConnClark 11-14-2011 07:13 PM
Correction. It uses heat to create the mechanical motion to pump the heat.
Edit: Let me elaborate. Some of the energy goes to move the pistons and gasses around. The heat pumping is largely done by fluctuating gas pressures in the different areas.
