VW Öko-Polo - 138mpg?
I just came across this autoblog article:
https://www.autoblog.com/photos/1988...#slide-2288078 VW claimed it made 138mpg during a test drive, using an be 850cc supercharged diesel. I personally think that sounds a bit high, even for diesel. Maybe these were UK gallons? Neat car though. https://s.aolcdn.com/images/dims?cli...558&quality=80 |
Sure that sounds quite optimistic for such an old-school ride, but Diesels tended to respond greatly to forced induction anyway. It's also important to take note on any specific condition of that test-drive which might have influenced the results.
Superchargers are known for increasing efficiency on gasoline engines...but I assumed that was when at partial throttle, shoving more air in to each cylinder, getting it in to the more efficient part of the fuel map...something diesels don't have to be nearly so concerned with.
The 90's+ Buick 3.8 S/C cars get better gas mileage than the naturally aspirated versions, for example. With a diesel no suffering from as much pumping losses, I'd have thought a turbo - that only really kicks in when you need a lot of power - would be the most efficient way of doing it. Maybe it comes down to gearing...with even more low-end torque, you could run that sucker at like 1300rpm and still make enough power to keep it moving. Probably UK gallons. From Wikipedia: Quote:
I like the combination and results though. Stuff it in my insight, please! |
Very nice concept, of which 50 cars were built. In the next video there is some information about this early VW 3L car - in german - but with some graphs and a test drive that begins at 4:16.
It's quite progressive for that time! 27 hp in normal mode, 40 hp with the supercharger activated. A semi automatic gearbox, start/stop, coasting with engine off, but also emissions were taken into account, with EGR and a particulate filter. We're talking about 1987. https://www.youtube.com/watch?v=VS9VZxboDJc |
A nearly 50% power improvement with the supercharger on. When it comes to particulate filters, makes me wonder how the trapped particulate matter would be dealt with. There were some attempts to use particulate matter on rubber processing in Brazil, but AFAIK it was phased out even before DPF became mandatory on newer buses. Seems like it was just easier to burn the soot off instead of collect it and send it to rubber processing plants...
