Old 09-18-2009, 12:51 AM   #1 (permalink)
Auxillary vacuum reservoir
I haven't seen anyone do a stainless tank yet so I figured I'd throw this one up I just completed. This one (the large tank is for the brakes) has a volume of 126"^3, which should hopefully be equal to that of the brake booster itself so hopefully it will double my braking during EOC.
On my 12 minute drive to work 4.5 minutes of that is coasting at one time, it takes a bit of effort to stop even in my 2230 lb civic hatch when I run out of vacuum. These tanks are going in an Integra so hopefully they'll last all the way to the bottom of the mountain.
Last edited by greasemonkee; 09-19-2009 at 02:43 AM.. Reason: corrected measurements
Old 09-18-2009, 01:24 AM   #2 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Those look pretty nice. Where did they come from? I have a stainless tank in my Previa, also reclaimed. Mine is good for about 8 good, full stops. I also have a vac gauge to monitor the tank.
http://ecomodder.com/forum/showthrea...html#post67726
Those will look good under the hood! Are you leaving them together? What will you use the other for?
Old 09-18-2009, 02:05 AM   #3 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I planned on using some small aluminum oxygen tanks from a portable oxygen (breathing apparatus) setup. I have 3 long tanks and like 5 shorties that I can use. I'm not sure which ones I'll use, if I even bother with vacuum assisted brakes. (I don't need them, by any stretch of the imagination.)
Those certainly are nice tanks, though. I have some candy cobalt paint that would make them really stand out... LOL.
Old 09-18-2009, 02:48 AM   #4 (permalink)
I fabbed those tanks up here in the shop with left over exhaust parts, a 3" off my civic and 4" from a cummins. There was some aluminum laying around as well, but a bit more difficult to weld so I opted for the stainless scrap bin. A long 3.5" pipe under the bumper support would have worked better volume wise, but the darn AC line is in the way - the price for keeping accessories.
A gauge is a great idea and plan to install one myself.
2nd tank is for a MAP sensing throttle feedback system I'm working on.
Old 09-18-2009, 02:52 AM   #5 (permalink)
Long tube right between the head lights... there's no grille there anyway, so no point in leaving that space open, right?
Old 09-18-2009, 04:17 AM   #6 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
Thats some sweet welding there Greasemonkee! Looks like TIG although a 12 gauge rod could weld like that too.
ollie
Old 09-18-2009, 10:50 AM   #7 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Looks Good!!!
I'm glad your sticking with the MAP sensing throttle feedback system project.
Pressure Gradient Force
The Positive Side of the Number Line
Old 09-18-2009, 05:01 PM   #8 (permalink)
Eco Dreamer
Versa - '08 Nissan Versa SL Hatchback
Cool!
I ran out of of vacuum today coasting into my driveway; had to use the e-brake.
Got a best-ever 27mpg on my commute home from work though! Not bad considering before I started hypermiling I was averaging 13-16mpg.
Homemade PVC Vacuum Reservoir millenniumtree EcoModding Central 26 07-11-2014 01:50 PM
DIY Vacuum Forming cfg83 DIY / How-to 26 05-05-2011 01:53 PM
10-minute Accord vacuum gauge "install" Clev DIY / How-to 7 09-10-2010 03:53 AM
Woo Vacuum Pump! trebuchet03 The Lounge 10 05-14-2010 12:52 PM
Vacuum gauge: all or nothing! elhigh Instrumentation 2 04-23-2009 08:57 PM
