VX wrong trans
Problem. After some time now and finally gathering the funds, I was able to replace a transmission on my '95 Civic VX that was totally trashed.
Yep; pretty sure the shop installed a dx/lx trans instead of a cx/vx trans. From information gathered here and other sites, the VX should read about 2000 rpms @ 60 mph...mine reads 2400. 65 is 2600 & 70 is a whopping 2850-2900. Am I not correct that the VX should be @ about 1950-2000 going 60mph? I am sooooo annoyed that a shop didn't confirm what trans they were receiving and/or just decided that just because another trans WOULD fit that it was ok to install! Yep. After a couple phone calls to the shop that did the work, I'll have to head in personally. ugHHHHHHHHHHHHH!:mad::mad::mad: |
Sounds like they either get to replace it with the correct part, or pay for someone else to replace it with the correct part.
I'm sure they will argue with you, but just like if they had replaced your 1.5L engine with a 1.6L engine and told you that they were close enough, you would not be happy either, it's the wrong part, plane and simple. |
Exactly. Actually the guy from the shop called me shortly after I spoke with them to tell me they just ordered the correct trans and it is being shipped! He has agreed to take care of everything...potential headache averted. But I sure do like the gearing of the 'wrong' trans around town (not so much on the highway, though). And the shift quality of this trans is pretty darned nice, too.
I did supply the shop with Honda trans fluid and will do so again. It gives me peace of mind knowing they will be using that fluid even though it's something I shouldn't have to pay for this time. A couple questions: 1. Is there any difference in the length between gears VX/CX vs. DX/LX? I know the gearing is different, I mean the distance/throw while moving the shifter? 2. Will there be any difference in feel/shift quality or is the VX/CX inferior feeling straight from the factory compared to the other Civic models (assuming both are of similar age and condition)? I have never driven any of the other examples of Civics from '92-95, Next up I have to do something about the handling; the body roll is terrible! THANKS! |
For the most part the shift feel you are feeling is most likely the new fluid causing it to shift smoother.
How much is a VX or CX transmission these days ?
Both the same right? |
I paid $450 for a CX/VX (or at least I thought, see post above...!) that has 79K miles and is covered by the installer for 6 months (the replacement trans I have coming has 84K). I found cheaper units, some as cheap as 300, but they had higher miles and only came with a 90 day warranty. I plan to slowly but surely restore this car and wanted to get parts that I felt pretty confident would last for several years.
**So does anyone know if the distance traveled for the shifter or 'shift throw' of a CX/VX trans would be the same as a DX/LX trans? Will the quality of the shift feel as good? |
I think the difference in the two transmissions is in the final drive (differential) portion of the transmission. There are some better knowledgeable Honda members who can confirm or refute that belief.
regards Mech |
BTW, why not get a factory trans? As I recall, they are not a lot more pricey than this (labor excluded) and they would be new? Something I don't know about the costs or availability? Did you look into it? |
complete new transmission is $2017 Honda Automotive Parts.
Car-part.com has a few that have 10,000 miles and a whole bunch that have 50,000 miles on them. I had my first vx transmission have the main bearing go out at 230,000 miles and I drove it for another 5,000 or so before replacing it with a $150 used, 100,000 mile transmission, my current vx has 216,000 miles on it and the transmission is very smooth and quite. I suspect that what made my first tranny go out at 230,000 miles was the lack of mtf changes, when I bought it the owner at the time said the only thing he replaced on it for 100,000 miles was tires, exhaust and engine oil changes. |
Copyright ©2000 - 2021, vBulletin Solutions Inc.
