The one in the Maserati video at ?t=491
Ah.
Well that's a nice to have but unless pgfpro has had his chambers metal 3D printed with water cooling chambers incorperated he gets away without them.
He is able to use mixtures so lean that they burn 'cold' vs the usual 'too hot' thx to the turbo/s and fine pressure control and pre heating!
He does have water injection fitted, but I don't know if that just 1 big nozzle pre intake manifold, or 4 carefully positioned injectors aimed toward the chambers.
As he goes with water dissolved in his gasoline (or thinners), ethanol, methanol power mix I assume it's one big injector..?
Again; NB my '
round the sharp corners on the sparkplug's J electrode then buff/polish it' idea..!
Plug thread/s exposed to the chamber is also out. As are the 90 deg corners of the cylindrical bit.
I THINK that may be
my best (easy, cheap) pre-chamber anti knock idea yet!?
It's these 90 degree type sharp corners that get/stay hottest and originate knock.
Think of it this way:
Try make a metal plate red hot with a lighter.
Not going to work, but if the plate has a nice pointy corner, preferably with a machining burr; you may well get that to glow...
(Hmmm! Ive just had another idea, but a picture is worth a thousand words that hardly anyone will read and/or understand...
I'll work on a picture. Gotta get back into CAD!
I let that ball drop when TurboCAD changed the game completely with their 'new' windows version)
