Warm air intake? how about warm fuel?
the idea behind warm air intake is the fuel atomizes better, any one thought about warming fuel before its used by the motor?
This is how vegetable oil conversions thin the oil out for injection so it atomizes better.. they run the oil through heat exchangers that warm the veggie oil up to coolant temp.. Any thought or any one try it? |
I don't really buy the atomization bit for warm air intake. The real reason it works on some cars is because the ECU leans out the fuel mix to compensate for the lower oxygen content in the hot air.
That said, there've been a lot of "hot fuel mods" out there but I've never been convinced by one. |
I think there is depending on the circumstances. Diesel absolutely, gasoline in cold weather possibly, but gains would be less than diesel. I want to heat the fuel lines with electricity, does anybody have an idea of a product that works off 12V that I can wrap around a fuel line. I do not want to just wrap wire around my lines.
The Matrix/Corolla/Vibe/Celica (1ZZ engine) fuel rail is tucked in close to the engine with insulation around it. This is the first production fuel injected engine I've seen heat fuel. But, I'd have to say it'll work on some engine and not on others. Any engines designed close to the knock limit may not like warm fuel. So, its going to be one of those hit or miss things.
Check out post #27 here for pictures: http://forum.ecomodder.com/showthrea...5.html?p=22861 |
If your going to heat the fuel why use electric? causes more electrical load on your car, use that waste heat the motor makes so well, do a coolant exchanger.. can be as simple as a copper or aluminum pipe with-in a larger rubber heater hose. Thats how us Veggie Oil burners do it usually, or you can by small flat plate heat exchangers to do the same thing.
The ICE wastes so much energy as heat its ridiculous.. use it.. One other i though i has was a peltiere cooler type of device, there make ones that generate power from heat sources too, a big aray could replace your alternator.. no load , and recapturing that waste heat. |
Ebacherville,
Thanks for the suggestion but not going to happen at least right now while inder warranty. I want to do this on a diesel and I regularly see -15C start ups in the winter and I want something more instantaineous and diesels do not have an abundance of waste heat in the cold either. Also increased load is the best way to warm up a diesel in the cold so it is not as bad it seems. |
ebacherville -
I think this works, but you need to design a system that has discreet control over the fuel temp, especially in gassers. If the gasoline gets too hot, you can experience vapor lock (http://en.wikipedia.org/wiki/Vapour_lock). The "no cost" way to heat the fuel is to use the coolant hose as a heater, but that means you lose the discreet control I was talking about. Here is one (for diesels) that uses engine coolant : IN-LINE FUEL WARMERS http://www.arctic-fox.com/sitepages/pid43.php http://www.arctic-fox.com/images/products/inlines.jpg Here is another electric powered one for diesels that I would be terrified to use on gassers : HotlineŽ Electric In-Line Fuel Heater http://www.arctic-fox.com/sitepages/pid20.php http://www.arctic-fox.com/images/img/hot.jpg CarloSW2 |
Thats exactly what I wanted, thanks Carlos
Hope the price is reasonable. Edit: Sorry its close to what I want, I am looking for something to wrap around steel lines, I dont want to do intrusive mods right now. |
the fuel really can't get to the engine without getting warmed in a diesel or a gas. With gas engines warm fuel is actually a problem because it recirculated back to the tank causing higher vapor pressures in the tank. gasoline can slowly escape from the tank unless everything is perfect, thereby actually decreasing your fuel mileage before it ever gets to your fuel meter. this is not as much a problem for the diesel which can sit in an open bucket for month. with gasoline there is fuel lost before it ever gets to your car also. i would hate to think how much gasoline is lost before it gets to the engine.
there is web site in England i think where a gentleman does test all these types of ideas and product gimmicks. I did ask him specificly about this very question and he assured me it would not help for gas engines and went through all reasons why. you should be able to find a thread on this site about it. now if your an ice road trucker obviously your out there. out there. |
if your looking for a electric solution to wrap around steel lines, the veggie world uses stainless steeel welder wire, there are people in the veggie world that sell them there usualy called "injection line heaters" there just a certain length of stainless steel wire feed welder wire that makes a certain AMP load then there insulated in special high temp heat insulation and wrapped around the injection lines on the diesel engine. There usually cheap.. under $50 for 4 or 5 of them.. you can make them your self even cheaper.
As for vapor lock, The engine coolant hopefully would be cool enough to not lock it, you could use a automatic valve that coupled to a temp sensor to regulat the temps. |
I have a 2002 altima that does not recirculate fuel back to the tank. There is no return line. I Notice sever millage differences in winter from summer. I know additives to gas are a contributing factor, but temperature also seems an inevitable culprit. I have created a device from a coil of copper tubing that incased inside a 3"copper chamber with reducers on both ends. I have it installed so the chamber is filled with coolant. And fuel can flow through the coil. I just have connected the fuel side. Maybe next winter.
I got scared. Anyone else try something like this. Any input would be appreciated. ________ `\/\/\/\/\/\/\_ --------- |
FYI, winter vs. summer fuel economy differences are caused by a wide number of variables: 9 reasons why your winter fuel economy bites! - MetroMPG.com . Food for thought.
The diesel folks who run WVO/SVO heat the fuel due to the viscosity in the fuel injector, not for efficiency. Below about 160°F, the veggie oil is too viscous.
If gasoline is heated post-fuel-pump, vapor lock is probably a moot point. |
Gasoline isn't even flammable, only its vapor is. So no one has any experience with this application at all? I searched for threads on this motor with no luck. |
thats not true, gasoline has a flash point down to -40 and then there are additaves to drop that... http://www.jdm-inc.com/files/Gasolin...ventional).pdf
Hi,
An interesting variation on this was used in the Ducati SuperMono -- instead of using a fuel injector that sprays a mist; they used an injector that sprayed a single stream of gas, aimed right at the center top of the piston. The fuel hits the hot metal piston crown and vaporizes -- and it cools the top of the piston better than an oil mist on the backside. The size of the piston/combustion chamber on this motorcycle required them to do this; and they ended up with a (counterbalanced) single cylinder engine that can rev up well over 10K RPM. |
Engine & fuel engineering - Smokey's Adiabatic Engine
Hot vapor induction. Doesn't look like anyone has really followed up on it to prove it does or doesn't work. I also seem to remember a patent on a system that injected fuel around the exhaust valve, vaporizing the gas and cooling the valve at the same time. Nothing ever came of that one either. We need a hardcore version of mythbusters to try some of this stuff out. |
I said this earlier in the post
You want fuel as cool as you can get it so long as they injectors and pumps can handle it. All fuel quenches the chamber whether its a vapor or a liquid or a mist. Obviously liquid quenches the most, then mist then vapor. the vapor only cools because its at a lower temperature. Any cooling of the cylinder allows for increased torque at a given rpm. That allows you to put slightly less fuel in and get a more complete combustion, intake, and exhaust. Cooling of the cylinder also drastically increases engine life(so long as its not drastic, like pouring water into a cylinder). |
You would definately want to wrap this tape in fiberglas or something similar ... to avoid the loss of precious heat. Watch the electrical shorts to the steel line(s)....:thumbup: |
Hey guys. I hadn't been on this blog in awhile and found this particular thread of interest. I've been studying this "kind" of "thing" for over 4 years now. I've researched many patents such as Smokey's and met those who have well known Ray Covey and or Tom Ogle of more recent patents related. There are always to many unknown variables in the people and the patents them-self to give any formal conclusion. Smokey was one to make sure KNOW ONE stepped on his ideas or ever lost (so he says) proprietary information. Direct words from Carrol Shelby himself was that Lee Iaccoca killed Smokies K Car idea utilizing the adiabatic system that Carrol himself was involved in (he didn't say to what extent). I used to give him free advertising space in my newspaper for one of his Children charities along with a popular restaurant owner here in Albuquerque.
Back to heating fuel. First off, particularly in gasoline the expansion rate of the fuel related to heat, can contribute to pressures that can escalate exponentially within a few degrees above 85 or so. Although we have high pressure pumps in our tanks to deliver fuel, the peculation effect of expanding fuel can easily override it. True however disassociation of fuel molecules can be achieved from the addition of heat in a very controlled environment and with a means to extract the fuel at that point controlling pressures. Also a means in which to deliver the fuel at that point, effectively,to the induction chamber. Thus while still obtaining oxygen density to maintain your proper A/F ratios. Most of the lighter elements such as Butinal (one of over 160 elements typically) have been utilized to run the vehicles. This is what Tom Ogle was doing to only find the heavier elements to the fuels formula still left in the tank. By the way his mileage I couldn't really verify from any one still living who was part of that, although Ray Coveys brother has confirmed the 100mpg in a 440ci Chrysler. However "it could hardly get moving from a dead start". Obviously running the engine at optimum lean "barely" burn. Yet still, the mileage was obtained. Warm air creates a number of problems that a 1st year or 2nd year physics student would understand related to ICE functions, however there are some basic benefits that due exist however current vehicles are not prepared to take advantage of it due to the nature of current designs. Unless you've structured a proper device and instillation on a non-computer controlled car it's pretty much a waste of time. Wrapping electrical tape around your fuel lines will be more of a waste of electrical energy depriving your alternator and ultimately utilizing more energy than a any kind of gain in mileage, which also may just create more problems depending on the pressure created due to fuel expansion. Pressure however can be a great way to disassociate the molecules as Gail Banks has very well proven in his drag racing truck in which over 30K PSI is behind the diesel in that truck to get about half a dozen runs from one gallon of diesel with a 1,200hp engine at WOT. View it here: Jay Leno's Garage However you will need a complete "system" to achieve the same to take advantage of pressurizing fuel. I've experimented with many ideas of varied ideaology and design. I am currently in the process of patenting two extraction devices that allow a regular gasoline engine or SIE to run on diesel, bio-fuels and of course gasoline. Designed for optimum power, efficiency and of course much cleaner emissions. I'll leave it at that and hope I answered a few questions without getting into very lengthy descriptions of operating systems, gasoline/ hydrocarbon based fuels chemistry etc. |
Warm air and fuel with diesels
VW TDIs and old diesel Mercedes (I had a 82 240D) also use the recirculation to continually preheat the fuel filters to avoid gelling. I have known a few biodieseler's who installed heater elements in their stock diesel tanks so they could run B100 all winter in the northeast, and it worked well for them. They did not do a SVO conversion, just got the elements out of single-tank conversion kits and did that one part. Seems like a thermo or disable switch for hot summer months might be good, but otherwise it's a solid practice. HTH! |
Yes, for diesel or denser based fuels such as vegetable oil, or kerosine, etc., Examples of heating these fuels go back to the early 1900's and even earlier. For similar reason you discussed above. However, heating gasoline or any variation of C8H18 will not work well without additional controls, as I explained why above. I ran my 1973 240D on vegi and diesel with ease. You can also "restructure" the diesel to gain better performance and mileage. My 240D was a dog otherwise, even with a standard transmission.
Speaking of .. I will show my own mod not far off, and notes of before and after, it ought to be as obvious as it seems. I rin a carb, and they are dranatic to such chores. Some may note that injections, everything electronic has heat. that is the desire for CAI on may vehicles. not to be faster, but for efficient, and get the air correct. |
Liquid gasoline injection
Are most automobile injectors aimed toward the center of the piston though? Are there "stream" injectors that would fit in place of OEM injectors? |
Some vehicles, such as the Cobalt SS turbo, have Direct injection. This actually allows them to run super lean under some conditions. However, they don't directly inject a stream of gasoline. This would result in very poor emissions under most cases. You want to atomize the fuel as much as possible to get a complete burn. You need as much surface area as possible. At higher RPM you only have a fraction of a second to completely burn all the gasoline as much as possible. Even then, most gasoline engines still send unburnt fuel down to the cat to be burned. For a diesel engine, the scenario is different. The reason why they need to warm fuel is in order to get it to atomize better. As the fuel warms, it's viscosity lowers. The lower viscosity allows the fuel to come out of the injector as a finer mist. This allows a more complete burn, because there is more surface area. Warm diesel fuel technically would have some thermodynamic influence on the burn temperature... but it would be so small as to be statistically insignificant, observable only on a calculator. Warm gasoline in the winter might actually have a bit of merit. In very cold areas, gasoline won't vaporize very well. But that being said, no mater WHAT you do, your not gonna get great mileage at -30. |
"Even then, most gasoline engines still send unburnt fuel down to the cat to be burned."
Sorry but this statement is inaccurate. Not entirely wrong, just inaccurate. Please understand I'm not being critical. Only in older cars was there an issue of actual gasoline particulates/ molecules that could still combust after exiting the exhaust chamber. All the fuel is "burnt" in the chamber on most any normally running fuel injected system by today's currant design. This is a misnomer from past systems. A catalytic converter is a device using a "catalyst" which entails platinum, palladium, and or rhodium, to change the exiting hydrocarbon emissions to a more neutralized chain lowering NOX and high Co2. The byproduct from most current designs is actually a larger percentage of H20. These are current bouts of information that currently mechanics receiving an SAE certification must know and learn to quantify through traditional computations. A lot of misinformation exists. After reading the Wikipedia I realized it can be mis-understood to some degree if one is not more familiar with considerable detail to currant SIE or basic ICE combustion and breakdown of variations of C8H18 based fuels. The utilization in terminology regarding "fuels" "gas" and "gasoline" have very distinct outputs in any equation related to ICE or basic SIE's. Thus most of the terminology gets mis-appropriated and from a technical stand point, through further conversations, becomes confusing or simply wrong from a technical level. So simply know that a "gas" is from the lighter elements as Methane, CH4 and others related to Naphtha with in the hydrocarbon chain from C4,5,6 & 7 to liquid "fuels" such as gasoline, diesel and Kerosene. Gasoline typically being at about C8H18. Not at all trying to be an ass, but to help clarify terminology that just leads to confusion in an area where most people would like to know more about in order to make significant changes when it comes to understanding mileage gains from the ICE side. Here is some information that better illustrates the complexities of the combustion process as related to thermal release from the fuel and related to ICE and related to complete burn of the fuels utilized: Influence of a Combustion Parametric Model on the Cyclic Angular Speed of Internal Combustion Engines. Part I: Setup for Sensitivity Analysis - Energy & Fuels (ACS Publications) Here's information related from an engineering forum showing their debates via quantification related (initially they are talking about a compressed gas related to ICE,but change relations to gasoline ICE): Engine & fuel engineering - water + hot gas + cilinder = ? A lot of very well written and detailed papers have to be bought, which is really unfortunate, but I listed this one regarding "Effect of Engine and Fuel Variables on Liquid Fuel Transport Into the Cylinder in Port-Injected SI Engines" by Dr. John Heywood from MIT anyway. It's a very good explanation: Effect of Engine and Fuel Variables on Liquid Fuel Transport Into the Cylinder in Port-Injected SI Engines |
sorry,
Hydrocarbon Emissions would have been more accurate. |
so I have devised a copper pipe with a 2' coil of smaller copper tube i have it installed in my car with coolant running through it. I never connect the fuel line (copper tubing) so it runst through the coolant.
What your saying is that if connected,my fuel pressure will be too erratic for the car to operate correctly? once the fuel is being heated by the engine coolant? |
Fuel Heater
I just installed a plate type heat exchanger to heat my fuel. The car is a '97 2.5 liter Subaru. I am now getting cylinder misfire codes which leads me to believe it is significantly leans the mixture, why I am not sure yet. I did modify the fuel system so as to only heat the fuel going to the injectors instead of the whole tank. Still working on it.
Actually you may be heating the fuel so much you're getting perculation in the line which is real common in relation to the expansion rate of C8H18 and its other chemical additions. This will overcome the fuel pumps rated pressure.
BTW, most attempts at heating fuel via these methods, often negate negative results. Helping to disassociate fuel molecules becomes much more complicated than just adding heat or trying to get the fuel to absorb heat energy. Petrol, having internal chemical energy, has more properties to control at different levels of heat absorption, making it much more difficult to control. Something to think about. |
