What about Exhaust heat powered air conditioning?
Pretty much like propane gas refrigerators
Only using exhaust heat instead of propane gas as the heat source? HowStuffWorks "Gas and Propane Refrigerators" Absorption refrigerator - Wikipedia, the free encyclopedia |
Draw back is that they tend to be heavy, bulky and they don't like being moved and the refrigerant is very flammable and under a great deal of pressure.
RV's tend to use absorption refrigeration in their fridges and when something goes wrong with it the common fix is to pull the unit, flip it on to it's top and leave it like that for a day or two, much harder to do that with a car. |
Years ago I was on a caboose that had a combination electric/gas refrigerator on it, it didn't seem that bulky. It would have been a whole lot harder to turn over a caboose than a car.:D Chumly
-mort |
LP fridges tend to have very thick heavy coils while compressor refrigeration tends to have much thinner coils, I assume that this is part of the reason for the increased cost in an absorption fridge, but if you want to make one your self they are not that hard, just be careful not to get your self killed. |
[QUOTE=Ryland;317461]Trains and RV's tend to have a lot more bulk to them and are a lot smoother then passenger cars.
Are you kidding? Apparently you have never ridden a caboose on the rear of an 80-130 car freight train. I have been knocked down by the slack running in and shortly after stood back up when it ran out (luckily the train didn't break in two).:eek: True, they have more bulk but most autos ride much better unless you are comparing to a passenger car. |
What RR still runs cabooses?
I grew up with an LP fridge and have helped a hand full of people out with theirs, we also own an Icy Ball, it's a very crude simple absorption cooler that you can heat up on your stove top, really neat but people are freaked out because they can blow up. |
