What is an Allroad and why can't even McGuyver keep one running?
Blame it on the electronics.
Blame it on the fact that you need more than a paperclip to fix a car.
Check out the timing chain:
https://i.imgur.com/XLnX99g.png Legend says the timing chain tensioners are plastic. |
Ahhh Audi. This is why I don't buy your cars.
What advantage does this spaghetti system offer over a good old Mazda timing chain, for instance. https://static.cargurus.com/images/s...1600x1200.jpeg Or even simpler, a nice Toyota: http://i118.photobucket.com/albums/o...e.jpg~original |
Sometimes I wonder why would Audi develop its own wide-angle V6 instead of simply resorting to the VR6. Or simply keeping the straight-5.
Fat?! My wife got her picture taken with Richard Dean Anderson earlier this year. He's leaned out quite a bit since then...he looks good.
Don't even get me started on VW stuff. The two 2000 VWs my parents had occupied both extremes of the reliability spectrum. But from what I gather, a "reliable VW" is usually an oxymoron. |
I wonder if old Volkswagens are still more reliable than new ones.
My current VW has had no issues. I'm still not keeping it out of warranty.
I usually say the problem with Volkswagen is its owners who seem to expect the newer ones to stand to abuse and neglect much like a Beetle or a Dasher would do. Well, considering that Volkswagen still has a strong foothold in my POS of a home country with its harsh road and environmental conditions, it may not be so unreliable at all.
Dashboard-light's data has much to say on the topic:
http://www.dashboard-light.com/vehic...swagen.png?v=4 Just as an example, Honda/Acura lost a lot of points for selling an Isuzu on their lots for a while, and for the disaster that was their V6 automatic transmission during the early 2000's. How the crap did VW/Audi get a score like that? I was under the impression older Beetles weren't particularly reliable, at least when you look at life expetancy. Sure, there weren't a ton of poorly built parts to fail, but how many 1500sp's (just as an example) are still high compression, burning zero oil and have needed no appreciable maintenance after 250,000 miles, as is common among modern engines? The plus side is (again, to my limited knowledge) that they're stupidly simple, easy, and inexpensive to fix. |
How in the world is Hummer between Toyota\Lexus and Scion?!
Then Porsche. This is a crazy world. |
Apparently the H2 and Boxter are/were just well put-together vehicles, which had few problems that would take them off the road. Electrical gremlins maybe, but nothing that would require a tow. |
Being easy to fix does not make them reliable, at least in my book. Cheap and attractive to own, sure. ;)
Maybe the rest of VAG should take a page or two from Porsche's book. |
If you can afford a used Porsche and the aforementioned maintenance - especially a Boxster or Cayman - I could think of worse things to buy. Good indie mechanics exist, too.
Independents can very often be the best! It's hard to know, though, except by choosing one and seeing by dumb luck how it goes. So far I have been lucky in being able to take care of most of my maintenance, but there's a timing belt lurking for the Hondizzle, so I'll have to make a choice at some point. |
How many sports cars are bought during mid-life crises? How much planning is generally done during that period? :)
I wonder why warp drive goes offline so often, and why transporter technology seems to be so shoddy in the 23rd century?
In fact, why can't a lost crewman be re constituted from transporter records? |
Lazy writing.
I stand corrected. Temperamental technology is a plot device.
Someone posted the meme in #1 again and somebody said that Anderson had recently broken his leg, and was suffering from medication side effects. There were some good MacGyver and Stargate references. |
Then a VW owner goes to the quick lube and gets the oil changed with cheap bulk conventional 10W-30 and wonders why the turbo fails. |
Valvoline - 881167-CS European Vehicle Full Synthetic XL-III SAE 5W-30 Motor Oil Purchased in bulk (3 x 5qt containers) it was $90 ($6 a quart). A basic 5W-30 synthetic blend is about $12-15 for a 5 QT bottle ($2.50 a quart) |
How much does it cost to properly maintain a German car overall? Is the oil change indicative?
There are tons of kinds of oil, and they're all different. The fewer vehicles in your market that take that exact oil, the more expensive it's going to be. Synthetic will be more expensive, and rare synthetic will be even higher.
My dad likes to lease Audis. He had a light out once and he asked the writer how much the whole job would have cost him if it hadn't been covered. The writer just laughed at him. I do recall peanut bulbs (194/168 and what have you) on a BMW not being replacable, instead being hard wired into the body wiring harness. Not one I had to deal with, but the shop that called me was complaining about the last car he had to deal with. |
2003 VW Jetta TDI 0 - 120K $2,751 2005 Toyota Prius 0 - 120K = $1,572 The big difference there is that I paid a mechanic to do the timing belt change on the TDI @ 100K miles which cost $1232. The Prius has a timing chain and I did all the work myself. The problem is that plenty of people just won't pay the extra $30 to use the proper oil in the VW. Then there are the people that are loyal to a brand of oil. "I've used Castrol GTX 10W-30 for 30 years on all my cars ....." You see this even with fleets that are running thousands of vehicle. The vast majority of US trucking fleets still run their semis on 15W-50 CK-4 oil instead of the 10W-30 FA-4 oil recommended by the manufacturer. |
So, German cars are reasonable as long as you invest in regular maintenance.
What about Fiats? :D |
After about 200K miles stuff on the interior started breaking - pretty common for any car that has been heat cycling in the Alabama sun for years. My brother had similar luck with a Jetta sedan TDI of the same vintage. My 2014 Jetta Sportwagen is too young to have issues. To date the only repair was the sunroof seal - replaced under CPO warranty. (I hate sunroofs) |
Dutch summers must be brutal too then as the interior of my '86 Deasel single cam Rabbit started crumbling like crazy in just, err, 18 years...
By then it had 390.000 km on the odo, and I switched off the engine before rolling to a stop so I would not have to exit the car in a cloud of black smoke. Then a fairy coughed on the front bumper, and everything caved in like a soufflé in a hail storm. The headlights were facing each other. I pulled it back in shape with my bare hands, then drove it to the wrecking yard well aware that the crumpling zone actually started at my ankles. The VW was the worst car I ever owned by a margin, even though it got the highest mileage. But the stories... I once got it jump started by two policemen. By the time it finally ran they were sweating and cursing. That sloshing sound in the boot, fuel? No, window wiper fluid. It had a big tank under the bonnet and it emptied itself rather quickly - into the boot... I did not know whether it was green or black when I first saw it. It was my then girlfriend's car, she drove it for 1500 km a year - a diesel, mind you - and obviously never ever washed it. When I did it turned out to be white. We're married now and the Rabbit is gone. Life is good ;) |
