Old 12-27-2009, 01:42 PM   #1 (permalink)
'95 Geo with black exhaust pipe
I'm hoping someone can help more than the Chilton's manual has.
1995 Geo Metro 1.0L / 5speed with 160k miles.
Starts and runs great whether hot or cold.
Used mostly used on rural roads 35-50 mph.
Compression is 180 on all cylinders.
No oil consumption.
Exhaust pipe is black with a little soot ring around the outside as well.
I get about 42-45 mpg.
Ignition timing/valve timing are ok.
Everything I've tried has not helped with leaning out the mixture.
O2 sensor replaced no change.
I stuck my ocilloscope on the O2 lead when engine was idling(warm)
The O2 voltage changes, but the waveform is a whole lot slower than the book calls for, although it's inside the parameters. When I injected a little unlit propane from my torch into the air cleaner horn, the voltage went all the way to the end of the parameter. When I turned off the torch valve, the voltage and waveform returned to previous.
Any suggestions would be greatly appreciated.
Old 12-27-2009, 02:00 PM   #2 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Advance the timing all the way to the stops.
Old 12-27-2009, 02:13 PM   #3 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
You might check in over at geometroforum dot com. The guys over there specialize in these cars.
Old 12-27-2009, 03:09 PM   #4 (permalink)
How far is that? I'm already 5 degrees farther than the book.
My hearing isn't what it used to be, so I'm a little worried about detonation.
There's a hill close by without any traffic noise so I can do some experimenting.
Thanks also for the geometroforum link
Old 12-27-2009, 03:40 PM   #5 (permalink)
No oil consumption.
I'm assuming you changed the air filter. What does the condition of the spark plugs look like?
At 160K miles, finding carbon buildup in an engine would not be surprising.
Is it fuel injected or carburetor? If it's a carb, that's what needs attention, as the mixture is off. Either way, throwing a can of fuel injector cleaner into the gas tank wouldn't hurt, and it might help.
Old 12-27-2009, 04:53 PM   #6 (permalink)
Air filter is clean and so is our air (I live on an island in the Pacific Northwest).
The car has throttle body injection.
I got the car a couple of years ago, it had a burned valve.
I took the head off, cleaned out any carbon in the EGR passages, head was in great shape. Plugs look fine mixturewise (tan).
Idle is fine, fast idle is perfect when started, starts in hot and cold weather.
Most driving is in light traffic 35 to 50 mph.
I work at home, so the car has only had about 5k miles on it in 2 years.
Drivability is great, just a BLACK FURRY tailpipe.
I've seen others of the same year with RUSTY pipes.
I just got back from draining the coolant, checking the vacuum hoses and EGR valve and throttlebody coolant passages. All are OK.
Thanks.
Old 12-27-2009, 05:31 PM   #7 (permalink)
If it ain't broke...
Old 12-27-2009, 06:39 PM   #8 (permalink)
I just think it ought to get better than 40+ mpg with the kind of driving I'm doing.
It would also be nice not to have to clean off black from its backside when I wash.
Posts here and on the geometroforum state people are easily getting 50+ MPG.
Idle is fine both hot and cold, but the tailpipe looks like it's stuck in warmup mode.
Old 12-27-2009, 08:31 PM   #9 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
take a look at the o2 sensor again and maybe try taking it out and testing it, I've had bad new o2 sensors.
Old 12-27-2009, 09:44 PM   #10 (permalink)
My gut feeling is that is the case.
However, short of that, a good diagnostician (I repair things other than cars for a living) looks for any clues mentioned, slight as they may be:
Maybe it's time to check that again. A previously seen and noted "burned valve" on a car that, down the road timewise, now has 160K might need a bit of attention to that detail.
Raising Exhaust 99LeCouch Aerodynamics 13 10-18-2009 05:51 AM
Does Exhaust Noise Play a Role in Fuel Economy? Metallover EcoModding Central 16 07-12-2009 09:47 PM
Civic Vx engine question. stock exhaust manifold vs. stock exhaust manifold vtecn8ive DIY / How-to 3 07-12-2009 01:07 PM
Exhaust - beating a dead horse soycory EcoModding Central 8 04-27-2009 10:24 AM
exhaust and muffler for a 1990 Geo Metro base model 90metro Off-Topic Tech 5 03-12-2009 12:34 PM
