What to buy?
What kind of bike should i buy? the model please. What would be the most eco-friendly bike that i could purchase?
A used bike. :)
Welcome! |
Depends on your driving needs. Generally speaking, you'd want to aim for the smallest displacement that will suit those needs. Of course, not all engines are equal, so it can't be completely simplified to that extent...
Tough to beat a bicycle recycled off a junk pile. That's what I do.
i don't know about that, i have found myself beating a number of junk bikes as i fixem
but for a motorcycle, if you have little experience the simplicity and low cost of a gy6 150 make for a good start if you want on the highway then you'll prly want a ninja 250 or a rebel 250 i like the rebel body but the ninja twin is a really nice motor |
A 125cc Honda motorcycle is very common in that part of the world. Anything you buy will benefit from a full body fairing system and gear changes. Compare the compression ratio and the weight of bikes you have available.
First question: where are you going to use the motorcycle? Mostly city? Road? Occasional need for some off-road aptitude?
Second question: is there any 125-150cc motorcycle available with electronic injection there in Sri Lanka? Third question: are you going to carry a pillion passenger frequently or any overweight load? |
1. Mostly its going to be for work, so in the city
2. Yes 3. No Im not going for an overweight load |
ha ha:D get a Cub
TVS
Honda Suzuki Yamaha These are some brands available in sri lanka I don't know much about bikes but hoping to learn more can you please tell me what kind of advantages and disadvantages the bikes have |
Most companies have several styles of bikes: sport, cruiser, and dual/off road. Within each class the bikes are very similar mechanically. It may come down to sitting on each make and model to see which is most comfortable. The other consideration is the quality of dealer service and price of parts. If you streamline the bike then you may want to change gearing to run at lower engine RPM to save fuel.
Scooters and "cubs" tend to have lower-revving engines with a horizontal cylinder layout, and a lower output that is also paired with a gear ratio that renders them more suitable to city traffic. |
Do you know how to shift gears? Left hand: clutch lever and left toe: gear shift.
So, usually the shift pattern is 1 - N - 2 - 3 - 4 - 5 |
Money spent on bikes is never wasted! Get a nice 'last years' model, decent frame with Shimano 105 group set, comfort geometry and a women specific saddle. Decathlon will have something around £600.
