What can I do?
http://upload.wikimedia.org/wikipedi...31/1997MPV.jpg
This is a picture of my model car; although it doesn't have a roof rack or a bug deflector. I'm planning on a antenna delete as well as the passenger side windshield wiper. I have the 2wd version so it sits a little lower. I'm thinking about a half body pan or w/e and also a bottom grill block. Are there any other things I can do? I will be buying new tires soon, the stock ones are 215/60/idk rim size. :turtle: |
I just removed the engine fan, watching the guages now. It's not very hot here right now so i'm not going to worry about it. I also removed the silencer to the intake and it's getting air from inside the engine bay now, so that should make a hot-air-intake.
Have you had a look at the mods list? There are a lot of different aero ideas in there.
60+ Vehicle modifications for better fuel economy - EcoModder.com |
I wouldn't think the pass wiper will do much since your windshield is very upright.
I call for an air dam on the front or maybe a belly pan to smoothen up the rough underside. Would also say mirror deletes but you sit up high off the road - might need to see little cars next to you with the outside mirror. |
I have a new thread started here: http://ecomodder.com/forum/showthrea...30-a-7677.html
