Old 11-17-2008, 02:12 PM   #1 (permalink)
Eco-Noob
PonchoBuick's Avatar
"da bus" - '94 Dodge Caravan base
90 day: 18.25 mpg (US)
"da Oldsmoblubble" - '83 Oldsmobile Cutlass Supreme
90 day: 9.95 mpg (US)
What effect from tire size and type?
Just wanted to throw this out here. My '94 Caravan has been running on 215/70R14 Indy 500 Firehawk performance tires for about 3 years now. The original tire for the van was 195/75R14, a normal passenger type radial. I've since returned to the original tire size over the last two weeks since the wider tires seem not to like being under the van. Does anybody think that difference in size would have a large effect on the FE, especially going from a performance oriented tire to an original style passenger tread? The new ones are Bridgestone Insignias. Any thoughts?
Aaron
Old 11-17-2008, 04:03 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
PonchoBuick -
I went here :
(Miata) Tire size calculator
And made this comparison :
I also went here :
Car Bibles : The Wheel and Tyre Bible Page 2 of 2
And got the same result :
From the above, the revolutions per mile look very close. Still, I think you should do a GPS comparison to your odometer. That's what I have done :
http://ecomodder.com/forum/showthrea...ires-2642.html
I am not sure how to quantify the width, but I agree that performance tires have a bigger contact patch and are more sticky (increased Rolling Resistance). Because the tire diameters are so close, I think you made a good choice.
CarloSW2
ID:	2146   Click image for larger version
American Solar Energy Society
100+ hypermiling / ecodriving tips & tactics MetroMPG Hypermiling / EcoDriver's Ed 457 02-11-2022 03:57 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Tire size and FE with a Jeep zjrog Off-Topic Tech 22 01-24-2011 10:32 PM
change in tire size mully General Efficiency Discussion 8 09-28-2008 08:13 AM
SAE Paper 800087 – The Effect of Inflation Pressure on Bias, Bias-Belted, and Radial CapriRacer Hypermiling / EcoDriver's Ed 18 07-06-2008 06:36 PM
