EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   What to do for 1999 Honda CRV? (https://ecomodder.com/forum/showthread.php/what-do-1999-honda-crv-17822.html)
Minibear453 06-13-2011 08:24 PM
Hey guys, I'm about to start driving, and I'm going to be driving a 1999 Honda CRV. What would be the best/easiest mods to do to increase FE? Right now, I'm shying away from those insane boat tails, and things that need a lot of mechanical experience. Suggestions?
cleanspeed1 06-13-2011 10:14 PM
Cover the basics as far as tune up, oil change, tire pressures, and then look at the efficiency mods and hypermiling techniques. If you don't need the space of a CR-V, consider getting a Civic.
Minibear453 06-14-2011 02:04 AM
Eh... what hypermiling techniques can I use? Things like the pulse and glide, will it work with an automatic? The only thing I can think of is drive slow, not accelerate quick, and no brakes. And is going into neutral at stoplights good? I've heard people say there's more wear on the car...
