What does YOUR bike weigh?
So it occurred to me about 3 minutes ago that I've never weighed my bike, and therefore I have no clue what it weighs. Being ever the slave to my curiosity, I proceeded to grab my bathroom scale, head out into the garage and get my weigh-in on.
So my previous Wild A$$ Guess as to my bikes weight was somewhere between 25-30 lbs. So I was nearly giddy when I saw good old Margot weigh in at a svelte 43 lbs. :cool: I gotta quit pampering my bike so much, at 43 lbs. I can pretty much run it over with a Mack truck and not do any damage. :D So how much does your ride tip the scales at? |
If I'm not mistaken (and I may be... a little foggy on this one), I think my old Pirate Bike is exactly the same weight!
Mystical bicycle convergence?
You be the judge! :turtle: |
Now I have to go weigh it again. (OK, tomorrow I'll weigh it again.)
I already heap abuse on mine: earlier this fall, it slid down a rocky shoreline (steeply sloping shoreline, thus the problem) and fell about 5 feet into the St Lawrence river. I was sitting on a rock about 10 feet away at the time. I laughed. So did a few other people in the park who saw/heard the descent & watched the retrieval process. Fortunately I was not on it at the time. Also fortunately there was a way down (and up) to the water, and the water wasn't deep. The latest abuse: I left it out in the open for the first big snow/ice storm, and next time I rode it, the only lever or handle that wasn't frozen solid was the front brake! (Not my preferred choice on snowy roads.) |
*Gear inches is the distance that your bike moves with every complete revolution of the cranks* |
My bikes is pretty much a porker at 58cm and 23 pounds! I want it to be sub20 eventually, which I think is decent for a 58cm bike. Oh wellz.
OK, it's not quite in the same league as your 43 lb porker.
37.5 lbs. |
Mine comes in just under 21. Woot:) |
The problem for me is I don't know where the weight it right now. I'm going to get a new set of wheels at some point, which should kick 2 pounds off, but other than that I'm guessing it's just in the frame. I really don't care that much about the weight though, and I like the look of my frame more than the newer carbon frames anyway. *shrug*
25lbs with spare tube and frame pump, but my bike is useless for anything except going fast. No rack eyelets and no tires over 28mm.
4 Attachment(s)
Currently Riding this 'Bent
http://ecomodder.com/forum/attachmen...1&d=1196909575 It's a beast - 45 pounds of cheap imported mild steel :D When not riding the 'bent... I'm riding this.... http://ecomodder.com/forum/attachmen...1&d=1196910338 No clue how much it weighs... But it's a very old lugged cro-moly frame + the obvious extras :) (It is an old picture - I do have brakes and a better seat etc.). It's not mine (either one), but it gets some use (one in foreground): 2007 UCF HPV http://ecomodder.com/forum/attachmen...1&d=1196909714 It is also a pig... At 90 pounds :eek: Luckily, most of that is in the fairing - and we're optimizing for weight for next year's HPV. Trying to Buy: http://ecomodder.com/forum/attachmen...1&d=1196910088 32 pounds (not the lightest - but very nice :) ) Luckily for me - there's no appreciable hills (well, no hills really - just gentle slopes) :D So weight isn't really a factor that concerns me :p Oh yeah... I like bikes. Especially your not so average variety. I'd commute to school on a penny farthing if I had one :) |
Getting OT, but a question for trebuchet:
What's the deal with under seat steering on bents? The only bent I've ridden for any length of time was this BikeE (which was a complete blast), but I have to think that hip level steering would be so much more comfortable. Plus cooler looking. Is it harder to ride? Less inherently stable, or something? |
Theoretically, the steering is exactly the same. But at first, you may psych yourself out enough to make your steering a bit wonky. But just like riding a recumbent in general... It's no more difficult than riding a bike. It's different, yes - but not more difficult :) I personally prefer ASS - I've ridden both (and direct steer - in that velo-trike) - no particular reason though :p |
countersTrike |
A couple of 65 cms... One's 29½# and the other is 20# which is pretty good for the frame size, but I've drank from sturdier beer cans. The heavier has a low of 28x28 with the triple but the lighter with its 39x29 gearing still does way better climbing. Did Boston Montreal Boston on the heavier one, but it was probably around 45-50# with all the junk loaded on.
I want a Seven Axiom but I can't convince my better half to hook on street corners so that I could afford it... :p:p |
http://www.flickr.com/photos/16584749@N00/2047823631/ And yes, I know I left the helmet on top, and I know I left my foot on the ground- I will never live that down! countersTrike |
$3200 Yep, thats reassuringly out of my price range. |
Bike weight
In cycling circles it is well known that to reduce weight, the most cost effective is to reduce rider mass. If you are already in the low end of the BMI, well done, then you can start to lighten the bike (IMHO). I used the following order as I wanted to keep the frame.
1. Remove any unnecessary equipment (wide to narrow tyres, racks, heavy repair kit) 2. Lighter versions of big things that spin (wheels, cranks) 3. Lighter versions of little things that spin (hubs, chainrings, clusters, pedals, shoes) I ride an M5 Shockproof CroMoly 15kg or 33 pounds. It is very comfortable and aerodynamic. I usually ride with other guys on 8 to 12 kg standard frame bikes and can keep up quite well. They are faster up the hills as they are lighter and their bikes are lighter. My total rider bike weight is 100kg. My buddies come in around 80kg. My current average speed over all terrain is 27kmh (17mph) and is getting better for two reasons. I am losing body weight and I am getting fitter. I also use the rolling momentum down the hill to assist going up the next one as much as possible. Hope this helps. Brad |
1 Attachment(s)
------ So here's my latest... And final purchase for a long while... http://forum.ecomodder.com/attachmen...1&d=1199846855 It's a Challenge Distance... The older, slightly fatter variant of the Challenge Seiran Weight Fully loaded (what you see in the photo plus head/tail lights and mount and fenders).... ~40 pounds - scale isn't exactly accurate. So Vehicle + rider is ~175 pounds (79kg) |
