EcoModder.com
-   The Lounge (https://ecomodder.com/forum/lounge.html)
-   -   What on earth is this?! (https://ecomodder.com/forum/showthread.php/what-earth-39599.html)
Xist 07-25-2021 03:16 AM
I found this on Imgur:
https://youtube.com/watch?v=Vv_nO2_QZX0
That is a YouTube link to the video shared here:When the kraken starts to rise. The poster provided zero information and the only guess was that an empty pipe at the bottom of the lake began to float up because it was filled with air.
What language are they speaking?!
RedDevil 07-25-2021 04:23 AM
I've read that even ancient stone coffins can emerge from the soil after an earthquake.
In China they put the dead in stone coffins and sank them down in a grave pit filled with water, then put earth over it to fill the pit and drive away the water.
But while the coffins are heavier than their volume in water, they are lighter than the same volume in mud, and only the weight of the soil on top of them prevents them from floating up.
Until something disturbs the waterlogged soil, like an earthquake. The soil becomes fluid and streams down past the sides of the coffin while that moves up.
We don't know what went up there, but I would not bet on it being filled with air. It could do the same if it was filled with water or oil or whatever substance, as long as it is less dense than the mud around it.
Xist 07-25-2021 04:45 AM
So far nobody knows what this is, but at least we know where this is, and what language they are speaking: Land Rises Above Water Body In Haryana, Video Leaves People Stunned
redneck 07-25-2021 05:13 AM
https://www.youtube.com/watch?v=xVsI48kMB4k
:D
jakobnev 07-25-2021 05:25 AM
My friend guessed Marwadi, which is spoken in India.
oil pan 4 07-25-2021 01:24 PM
A pipe that is normally full of oil or water isn't.
Piotrsko 07-25-2021 05:54 PM
And that's why they don't bury people in New Orleans. Farmers will tell you rocks float.
