EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   What is Engine Load % - UG Question (https://ecomodder.com/forum/showthread.php/what-engine-load-ug-question-19078.html)
redpoint5 10-07-2011 10:29 PM
What is engine load %. What does it measure?
I'm guessing this is related to DWL, and I would think this is important to monitor for fuel efficiency.
If so, what % should I be aiming for?
gone-ot 10-08-2011 02:17 PM
...that's probably going to be an "...ask the UG manufacturer..." question, because it's a derived parameter and probably all done in software and using assumptions about engine performance. What algorithm and assumptions they use is anybody's guess.
redpoint5 10-08-2011 03:52 PM
Ah, just thought maybe someone had already found out the info, considering the popularity of the UG and the inquiring minds of those on this forum.
user removed 10-08-2011 09:12 PM
Load is a function of measured manifold vacuum. When there is no restriction meaning 0 manifold vacuum then you have 100% load without enrichment. As you increase the throttle position to 100% you reach a point where the ECU will provide enrichment for additional power.
If you do not consider full load enrichment, then load is directly proportional to manifold vacuum. MAP (manifold absolute pressure) is the measurement of pressure actually delivered to the combustion chamber. Manifold vacuum is the remaining atmospheric pressure not allowed in to the combustion chamber.
Atmospheric pressure varies with climate, altitude, and density. MAP readings cover this, while manifold vacuum does not tell you what the atmospheric pressure reading is, just the difference between atmospheric pressure and the remaining atmospheric pressure delivered to the cylinders for compression.
Make any sense?
regards
Mech
JRMichler 10-08-2011 10:43 PM
When I saw a fairly large %LOD on my Scangauge at idle, I lost interest in using LOD for driving. I now use MAP, Manifold Absolute Pressure.
The exact numbers are not as important as minimizing variation. I use it as a steady foot indicator.
redpoint5 10-10-2011 12:20 AM
I have been aiming for 80% engine load during acceleration for no reason other than I heard engines are generally most efficient (most unit power per unit fuel) at 80% of full capacity. I don't know if 80% engine load equates to 80% capacity, or the basis of the 80% claim in general. Any info on this appreciated.
Thank you Old Mech for the detailed explanation of manifold vacuum and MAP.
FYI, my UG shows something like 25% Engine Load at idle, and falls several points below 100% at WOT.
TX_Dj 11-08-2011 12:43 PM
The explanation of how it is calculated is interesting to me... since my engine generates zero vacuum...
I'm sure it's true, many of the derived gauges do not apply directly or necessarily accurately to diesel owners.
I have seen engine load % reported by some obd2 diagnostic tools, as some ecm's actually report this themselves. I don't know if this is necessarily the case for your vehicle or mine, or if the number represented by UG is reading from this or calculating its own. In my case, I'm noticing that I rarely show it over 25-30% during acceleration so far, which seems fairly accurate... 25-30% of 500 HP is 125-150 HP or 250-300 ft-lbs if based of my torque number. It's a heavy truck, it takes a lot or power to ramp up to speed even when gentle with it. Even still, this seems a little crazy, because even at stock power the way I accelerate for economy, I'd expect the actual HP/tq numbers for acceleration to be much lower, probably even half of above.
This brings me to other gauges that I believe to be derived from other sensors, such as the HP/Torque gauges (I think that's an EM-only feature, some of you may not have it). The setup asked me for my peak torque and RPM numbers, which is roughly 1000 @ 1800 RPM... at the wheel. As such, UG tells me that I'm idling at 505.6 ft-lbs, which is absurd. It also tells me I'm idling at 75+ HP, which is equally as absurd. It knows my boost is at 0 (approx) at idle, and I know the engine doesn't produce that power except under 100% load with 35+ psi boost...
I don't know if these and others are "off" though, due to the fact my UG has never seen this engine opened up (maybe it rethinks things when it sees what power it really has, otherwise just assumes it's a 3 cylinder eco box?) or if it's somehow related to the "Power on Demand" setting of my tuner. This setting is a scalar value of apparent arbitrary effect on the power output of the actual tuning program itself. That is to say, the engine + tuner will put about 500 HP / 1000 ft-lbs to pavement, but when I set PoD to "30", I get some amount of power below that of the stock program but with enhanced drive-ability- with higher rail pressures and more advanced timing for better fuel economy.
slowmover 11-08-2011 12:49 PM
I would like to know more as well. Relative simplicity. The "idea" of what load percentage the engine is working would be informative.
In the meantime, the old rule of 600-60-6 for steady state optimal FE offers some illumination:
Pyrometer at 600-F, or less
Road Speed at 60-mph, or less
Manifold Pressure Gauge at 6-psi, or less
It just isn't enough, though, for transitional states. At what rhythm to use the controls.
mwebb 11-08-2011 01:33 PM
calculated load - load - engine load
calculated load is an OBD2 PID , Parameter id
it is not unique to UG or SG or any other scan tool
it is a measurement of
calculated load -
the values used to measure load include MAP , MAF , Temp , RPM , throttle position and timing , there can be others
KISS
at cruise
lower calculated load translates to
improved fuel economy
at WOT increased calculated load translates better flow and to more power
expect around 90 to 95% calculated load at WOT at 4k rpm on a NA car
WITH real time fuel trim at +/- 5% FROM ZERO FUEL TRIM ADJUSTMENT -
if not
there are problems , depends which PID does not meet what is expected .
expect 150% calculated load at WOT over 4k rpm on a boosted system , same fuel trim conditions.
you can watch load change at idle
switch AC and Hi beams on while monitoring calculated load
Diesel_Dave 11-08-2011 04:20 PM
I'm not really familiar with the Ultragauge, but I believe %Load is an estimate of the amount of torque your engine is producing, divided by the max torque at that rpm. Torque is basicaly propostional to fueling. On a gas engine fueling is proportial to air flow and air flow is proportional to intake presssure. On a diesel, the ECM commands the fueling directly.
As far as the usefulness goes, %Load will basically tell you where you are vertically on a BSFC map (0% is at the bottom, 50% is halfway up, etc).
user removed 11-08-2011 04:53 PM
You can have very low manifold vacuum even at low percentages of throttle position. This happens when you are using a higher gear and less throttle to accelerate. If you have the ability to read manifold vacuum this will be about 1 to 2 inches of vacuum reading. If you are in the correct range of gearing you will accelerate efficiently.
Conversely, if you are reading MAP then it will be above 80-90% when you are in higher gears and accelerating at the best RPM range. If you go to the next gear higher and do not achieve the desired rate of acceleration then the lower gear is the best choice. This is because you can take much longer to reach the desired speed if you choose too high a gear. Fortunately I found the best rate of acceleration to be right at what traffic normally accelerates from a stop. This way you are neither pushing the car in front or impeding the car behind you, which in either case can cause the drivers around you to do stupid things that increase your danger of an incident.
You can alter your rate of acceleration by using higher or lower gears, but as long as you maintain a consistent load at 80-90% you will get to speed with the least fuel. You can go too far in either direction to high a gear and you do not accelerate rapidly enough and spend to much time using to much fuel. To low a gear and your RPMs go beyond your best BSFC range.
Think of climbing a grade. As the grade increases you are forced to decide to downshift or loose speed. When the gear you are in can no longer maintain your desired speed then you go to a lower gear while maintaining the same load and BSFC. Some engines might do well at 1500 RPM while others will need to be at 2500 RPM. Looking at your specific BSFC chart will show you the best range of RPM to maintain highest efficiency. Just keep the load at the 80-90% point. It may be only 30-40% of the available range of your throttle position, but if you are at the correct MAP or vacuum, then you are getting the most for your energy use.
While it may seem to be you are using to much fuel at that instant when you are at best BSFC, you must understand that best BSFC is never lowest fuel consumption overall. It is the most power you can create for the least amount of fuel. Increasing the velocity of you vehicle is storing energy in the faster mass of the vehicle itself. Then you spend that energy coasting with no fuel consumed (engine off) or very little fuel consumed (engine idling). While engine off is the best, if your car is an automatic and you must keep the engine idling to operate the oil pump in the transmission you can still coast with very high MPG.
Lets say my Maxima is coming off the Interstate at 65 MPH. I shift into neutral with the engine idling. If my engine uses .3 GPH idling, and I could coast for an hour like that, then I would get about 200 MPG coasting for that time period. It would be infinite if I turned the engine off but it would also destroy my transmission, so I let it idle.
regards
Mech
Diesel_Dave 11-08-2011 04:58 PM
I don't know why the UG would need to know the peak torque value for setup. And the toque value would be at the flywheel, not at the wheels. Where did you get the 1000 lb-ft @1800 rpm number. Stock peak torque is somewhere in the 600 lb-ft range I believe.
As an aside, I don't think you really need 500hp if you're going for FE. By my calculations, 500 hp will accelerate that 7900 lb truck of yours from 0-60 mph in 3.46 sec. :D
TX_Dj 11-08-2011 06:18 PM
Dave,
The numbers are approximated based off of dyno results of a friend's truck, one which is not setup quite as well as mine. He pulled about 480 HP / 960 ft-lbs on a recent dyno day. I have better air/exhaust setup than him and run a higher output program, thus I'm nudging his numbers up just slightly for my estimate. I was hoping to hit a dyno this past weekend, but that didn't happen.
I can't shift fast enough for a 0-60 like that, and don't have access to 500 HP throughout the RPM range, obviously. My buddy's truck is quicker than mine, since he has an auto, his shifts are quicker and his turbo stays spooled more between shifts. I'd need about 200 HP more than I have today in order to make up for gearbox lag... more for the extra torque than the horsepower, though.
The high power isn't there for FE, obviously. It's only there to have fun. It's rarely enabled, otherwise I'd get myself into trouble.
The UG is just one of the tools in my box now to help push my FE higher, and to gain a better appreciation for what changes make to the big picture. I never expected the HP/Torque numbers it shows to be reasonable, I just thought it was interesting that it thought I was making 505.6 ft-lbs at 0.38% engine load at idle. :D
Hopefully after a few weeks/months using UG I'll be in a better place with it all.
paulu 11-08-2011 07:18 PM
From the UG manual :
Estimated percent of engine load.
Where engine load is calculated as
% Load = (Current Air flow)/(Peak Air Flow)
Or
% Load = (Current Engine Torque)/(Peak Engine Torque)
The method used is vehicle dependent.
