EcoModder.com
-   -   What system will tell me instantaneous MPG on a 93 VX? (https://ecomodder.com/forum/showthread.php/what-system-will-tell-me-instantaneous-mpg-93-a-21607.html)
Joe1234 04-25-2012 12:04 AM
What system will tell me the most accurate, instantaneous MPG on a 1993 Civic VX? MPGuino? ScanGuage? It should only need to measure fuel amount and rpm to get the data it needs.
some_other_dave 04-25-2012 12:50 AM
The SG and UG work off of the OBD-2 bus in the car. Which is only present in 1996 and later cars, so your 93 won't work.
The MPGuino is pretty much your only choice. (Or SuperMID, I hear, but I also hear it does pretty much the exact same thing as the MPGuino.)
-soD
