EcoModder.com
-   Fossil Fuel Free (https://ecomodder.com/forum/fossil-fuel-free.html)
-   -   What would be an alternative to rubber tires? (https://ecomodder.com/forum/showthread.php/what-would-alternative-rubber-tires-17038.html)
theycallmeebryan 04-26-2011 04:28 PM
It takes approximately 7 gallons of oil, both in the formation of synthetic rubber and in energy, to produce 1 tire. (sited here: RMA: Rubber FAQs)
I have been wondering: What would be green, oil free alternatives to rubber tires (considering our access to natural rubber is pretty much none)?
dennyt 04-26-2011 04:51 PM
Crr .0001-.0020
http://www.discoverlivesteam.com/for...s/P1010053.JPG
Frank Lee 04-26-2011 04:55 PM
Leather?
markweatherill 04-26-2011 05:02 PM
Anti gravity! Of course, Big Oil has been suppressing this for years.
Ryland 04-26-2011 06:03 PM
28 gallons of oil to go 50,000 miles seems pretty good to me, 1785 miles per gallon for your tires.
I think if you want to make a larger impact getting low rolling resistance tires is going to off set the oil used to make the tires more then the increased rolling resistance of a sub par rubber compound.
Or you can take the train.
euromodder 04-26-2011 06:04 PM
Can't say I'm attracted by the idea :D
RobertSmalls 04-26-2011 07:05 PM
Bearing in mind the amount of energy required to produce wooden wagon wheels / leather tires / moon buggy spring arrays / tofu twheels, I'd say synthetic rubber tires are an absolute bargain considering how long they last.
euromodder 04-26-2011 07:23 PM
The Michelin Tweel uses a lot less rubber for starters, and what's on there should last longer
Christ 04-26-2011 07:59 PM
There isn't an alternative if you live in PA - the law requires pneumatic rubber tires on passenger cars.
DJBecker 04-28-2011 02:09 PM
Tires are pretty high-tech items already.
The rubber content is much lower than you expect. There is substantial weight in reinforcing fibers (steel, aramid/Kevlar, polyester). The "rubber" part is heavily filled with carbon (likely created from oil, but not certainly) and minerals (largely silica). And the polymer part is a complex mix of rubbers.
I don't know how you would fairly allocate the "oil cost" of a tire. I do know that almost everytime I see an estimate like that from an "environmentalist", it's a lie created by multiplying mis-matched numbers. ("Save two gallons of water by turning off the tap when you brush your teeth." Sure...) They should be working to get fair comparisons for tire compounds. (How can you find a sticky tire with long life and good energy return?) Not say "everything you do is bad" .
jakobnev 04-28-2011 02:48 PM
Asphalt wheels and rubber roads?
Joenavy85 04-28-2011 03:08 PM
RECYCLED rubber roads, can't get very more eco friendly than that
justjohn 04-28-2011 08:28 PM
If we got rubber roads I might actually start running again. :P
sid 04-28-2011 10:31 PM
I've ridden my bicycle on trails made from recycled rubber. There is an incredible amount of friction on those trails so you feel like you are pedaling through molasses. Most of those trails have since been re-surfaced with asphalt or concrete.
