What is wrong with my scangauge II?
I was driving and my scangauge II shut off then I pressed the home buton to turn it on, then it was frozen so I unplugged the wire and put it back in and now the symbols for RPM GPH and etc.. all have a square in front of them. Is my scangauge II broken or should I just leave it unplugged for a while. All my trip values and everything are all messed up and it says $6k in fuel and 2.4MPG which I know all of the values and none of them are correct. What do I do?
Did it get really hot or anything like that? I'd contact linear logic if it doesn't fix itself.
Unplug it, leave it inside somewhere cool.... then plug it back in. If its still all wacky, try resetting everything:
MORE >> MORE >> MORE >> USE DEFAULTS >> YES If all else fails, call up LL and tell them your troubles. |
I am getting some similar strange behavior on the today/previous day type data, I'm thinking it gets confused in hybrid mode and can't figure out when a day truly ends possibly? tank info seems to be pretty good and trip info is usually good so that's what i mostly care about anyway
Copyright ©2000 - 2021, vBulletin Solutions Inc.
