Wheel color schemes
I want to do forest green (British "racing green") pin stripes on my seven hole 12 lb Mini rims. But I prefer to keep the rims the stock silver/alloy color. Searching online, nobody combines these colors--or any pin stripe on a silver/alloy color rim. I am asking for opinions: forest green on silver is way ugly? I can't decide. And as an off-topic tech questions... should I put the striping under the clear plastidip or over? I think under.
Also interested in any fav color schemes for rims. Freebeard has a great color scheme on his beetle. |
Try it in vinyl or plastidip first and to see how it looks. It sounds outlandish to me, but I'm often pleasantly surprised.
Green and silver doesn't really sound garish to me at all. I suppose the only thing which might make it look a bit off would be if the green in question has a yellowishness to it, vs a more cool blue tone like a blue spruce.
3 Attachment(s)
Here are some examples. I could go for a gray wheel with the green on my black car. A lighter gray, almost a flat silver. What do ya think? http://ecomodder.com/forum/attachmen...1&d=1521215450 And here are two more images that come up when seeking forest green on gray instead of silver. http://ecomodder.com/forum/attachmen...1&d=1521215940 And a little scatology for your Friday: http://ecomodder.com/forum/attachmen...1&d=1521215962 Quote:
Interesting! The yellowish greens don't look so bad as I might have supposed. Wedding themed or not, you're good to go as far as I'm concerned :)
Any update OP? What color combo did you pick? Post some pics.
Basically, I could not do silver wheels because the wheels did not look as good on close inspection as I had thought. Some were great. One was really not that good. I wanted really clean wheels, so I went with painting them using plastidip I had on hand: black. I tested the green striping on the black dip, and I liked it okay (especially my striping tool). But the tool tore into some of the dip. It was suggested I should wait a month for the dip to cure before trying again. In the mean time I have become ambivalent about the thickness of the green stripe on black and think I would prefer a thinner stripe. A thinner stripe is more subtle and I would like that. I'll get back to it. So, here is a front wheel (with my painting of the tire lettering). And here is a back wheel (with stripe). http://ecomodder.com/forum/attachmen...1&d=1526692893 http://ecomodder.com/forum/attachmen...1&d=1523734234 EDIT: you might dig a back view too... 3000 miles later and holding fine: http://ecomodder.com/forum/attachmen...1&d=1523734212 |
What is the foil looking stuff covering the wheel openings?
I thought Forest Green was a Porsche color. I had a Forest Green Superbeetle. I repainted the wheels in Licht Grau (no picture). On the beige Superbeetle the chrome wheels were too blingy, so I two-toned them with white Plastidip:
https://ecomodder.com/forum/member-f...5-100-1036.jpg The rims that weren't Plastidipped aren't so blingy anymore. :( I'd consider black Plastidip to be a foundation for the pearl overcoats, like Bluminum. https://www.youtube.com/watch?v=j8kxuZaYh5o |
Forest green is a nice color.
