Which wheel cover is most aerodynamic?
4 Attachment(s)
Which of the wheel cover design is most aerodynamic in the attached images? I understand it could be hard to guess until or unless testing is performed using all of them, but I don't have that option since I can only purchase one of them.
Personally, I am inclined towards 03.jpg since it's close to what Tesla Model 3 have. |
My guess would be the suzuki one, then the honda one after that.
The answer to that is "no." Get the one you think looks prettiest. |
which?
2) I would point out that, two of the covers would be 'unidirectional,' and would only work on one side of the vehicle, not both. 3) You'd need 'mirror-images' of them for the other side. |
1 Attachment(s)
Also, does this mean the wheel cover that came with the car is best? Since, I can assume they must have tested it with the car thoroughly. |
Here's a thread on Tesla's wheel covers. There have been posts comparing generic wheel cover types but I haven't found it yet. Here is a thread with the one IIRC was best. ecomodder.com/forum/showthread.php/performance-car-aero-wheel-covers http://forums.pelicanparts.com/uploa...1138636043.jpg If looks are important, go with Moons. https://ecomodder.com/forum/member-f...8857-6lcms.jpg |
best ? tested ?
A recent clue about wheel cover aerodynamic windage/ventilation drag efficiency comes from Mercedes-Benz, and their EQXX concept car. You'll notice the low-porosity of the covers, kind of a nod to the MOON racing convex racing covers, typically used with all land speed records by all car manufacturers since the 1950s,and higher-performance aircraft manufacturers since around 1912 ( Derperdussin Monocoque ). Deperdussin-Racer | Aircraft | |
