EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Wheel skirt question (https://ecomodder.com/forum/showthread.php/wheel-skirt-question-8357.html)
philip1 05-13-2009 04:44 PM
I'm working on rear wheel skirts for my wagon.... I'm wondering how much I should cover? I have some inner fender bolts at about 3/4 the way down the opening. Will any be better than none or is it best to cover the whole opening?
cfg83 05-13-2009 06:12 PM
philip1 -
A full cover is always better, but I think you can use the bolts as part of the "infrastructure". Do you have a plastic fender liner like my Saturn S-Series? If yes, then you can make holes in that liner without having to cut into the metal frame of the car.
CarloSW2
philip1 05-13-2009 06:14 PM
Originally Posted by cfg83 (Post 104052)
philip1 -
CarloSW2
at 3/4 down I do beyond that its just fender. I think I'll try a 3/4 skirt and see what's what
