Wheel swap? 175/65-r15 Steel to 185/65-r14 Insight Wheels
Hi,
I recently purchased a 2017 Toyota Yaris L hatchback. I have added factory cruise control but am otherwise stock. I have run some fuel system cleaner through the first tank of gas. It's still using the factory 5w-30 oil from the dealer and has yet to reach the next OCI. I plan to switch to Mobile 1 0w-20 EP when the time comes. I drive around 25,000 miles per year. My drive is mostly 50 to 55 MPH with some 25 to 40 MPG stretches and may contain some 70 MPH expressway. When I first got the car I was getting around 37 to 38 MPG on the lie-o-meter. As colder temps and winter blend gas has set in I'm getting 35 to 36. I typically get significantly above the listed highway mileage as my average but i'm quite disappointed in the MPG so far. I think it would greatly benefit from a upper grill block and maybe a partial lower block. I don't have a scan gauge installed yet and will probably hold off till the dealer replaces a wiring harness next month on my car as part of a recall. The thing I'm interested in is it worth it to swap wheels for lower weight and aerodynamics? I previously owned a 2001 Honda Insight and those wheels were light weight and have the same 4x100mm holes spacing and a very close offset to the Toyota Yaris. I have tracked down a set of salvage insight wheels and lug covers for under $200. Going to a 14" aluminum wheel with great aerodynamics should help compared to the stock 15" steel with hubcaps. I am also a huge fan of Nokian's all weather tires. I have my sights set on their new WR-G4 tires. Unfortunately the only 14" size for that particular tire is 185/65-r14. The stock tire size is 175/65-r15. The purposed 14" tire has a higher weight rating so there shouldn't be any safety concerns. It's obviously 10mm wider than stock and about 2% smaller diameter. The total diameter of the tire is around 1/2" less so it should lower the ground clearance by 1/4". Unfortunately the car is already geared pretty short with a traditional 4 speed slush box automatic. I fear the changing the tire size to be 2% smaller may negate the expected fuel savings from a lighter wheel and tire package and aerodynamics. The other hangup is I would either need to buy a new set of TPMS sensors at $60 or pay probably $16 each to have them removed from the old wheels and have them moved to the new. Is it worth the trouble and $250+ to swap to wider shorter tires in the name of aerodynamics and lower wheel weight? Another option is to get a set of clip on racing disks for around $100. I plan to drive the car for 3 to 8 years as of now. Thanks for your suggestions. |
Welcome to Ecomodder! :)
If you block off part of your grille, be sure to monitor your engine temperature using more than just the indicator on your dash. Regarding wheels, switching from 18lb OEM alloy wheels and 17 lb tires to 11 lb HX rims and 16 lb tires on my Civic gained me 2-3 MPG. Lighter wheels find their biggest benefit in hilly driving and city driving. My rims were 15" and downsizing to 14" required using a 1/4" spacer. May or may not be a problem for you. Since you also live in Michigan, I would recommend getting winter tires. From what I've heard and seen Bridgestones are the best summer tires and Nokians are the best winter tires. Michelins are right up behind them. So to avoid having to remount tires every time the season changes, I would pick up a set of lightweight wheels for summertime, put summer LRR tires on them, and then put winter tires on your steelies. Going with a smaller diameter tire will essentially shorten your gearing and reduce fuel economy in most situations except hard city driving due to the smaller rolling diameter. Increasing your diameter will improve highway fuel economy, but slightly reduce city fuel economy due to the heavier weight. Going narrower is a good alternative. Both Insight rims (10.5 lbs) and HX rims (11 lbs) are excellent choices. If your stock tire size is 175/65R15, you would need 175/70R14s to keep the same size. Going narrower would be 165/75R14s, both of which aren't that common to find. Best bet would be Insight wheels + Bridgestone Potenza RE92s and a taller transmission swap to offset the shorter gearing from the wheels, but the return on investment for that would be in the hundreds of thousands of miles. :rolleyes: Don't spend a lot of money on rims if your goal is to save money. The return on investment will never be there. I spent only $100 on my HX rims and they haven't paid for themselves...yet. I will be using them as wheels for my Insight's winter tires, and that will count as a break even point for me. Insight rims are generally harder to find and more expensive than HX rims. Smooth coroplast discs are a very inexpensive way to do smooth wheel covers, but your opinion may vary depending on how important aesthetics are to you. |
https://ecomodder.com/forum/showthre...5-a-34939.html
Don't waster money on light weight wheels. A little bit of leg work saved me a lot of coin. The light weight wheels I was looking at were only about 2lb lighter than steel wheels. If you drive mostly highway lighter wheels will give the least benefit. For me I am going to replace my alloy nissan leaf wheels with steel wheels and aero covers. Concentrate on those aero mods. |
Also, remember to check if the smaller diameter wheels fit over your brakes.
Go bigger not smaller on the overall diameter.
With smaller tires you will see a MPG hit once the miles traveled are corrected. Can you get 185/65r15 tires? |
Thanks for the replies. I'm a long time lurker and huge geek.
I forgot to mention I also upped the tire PSI to 40 after the first couple weeks to get a baseline. As far as grill block and engine temperature I don't have a scan gauge yet. I guess I could use one of my ELM23 sensors and Torque pro android app. The Yaris doesn't even have a temperature gauge. It has a blue engine temp idiot light that is on when it's cold and a red light if it's too hot. On my 2001 Insight I just shoved a coroplast yard sign between the grill and the radiator during the winter. I live in Michigan and winter tires are a must in my book. I have recently been a big fan of Nokian's all-weather tires. They are different and not to be confused with all season tires. They are a softer winter compound but they were designed to hold up to heat and can be run year round. The are heavily siped and feature aggressive winter tire patterns. They aren't the best for noise vibration and harshness but if I was too concerned with that I wouldn't be driving a Yaris. I prefer the all weathers vs having to switch a dedicated set of winters and all season tires. If my car didn't have TPMS or had indirect TPMS I would probably just buy a separate set. I would really prefer to stick with the Nokian WR-G4 tires so my size selections are a bit limited. 185/65-R14 (Stock -2.04%) *Honda Insight Rims $250+ w/ moving TPMS 175/65-R15 (Stock tire size) *Stock 15" steel with OEM Hubcaps 185/65-R15 (Stock +2.14%) *Stock 15" steel with OEM Hubcaps 195/65-R15 (Stock +4.27%) *Stock 15" steel with OEM Hubcaps 205/65-R15 (Stock +6.41%) *Stock 15" steel with OEM Hubcaps 14" rims will fit fine. I have found a few posts detailing that 13" rims should fit the Yaris. Unfortunately there's not much good information out there on what size taller tiers fit in the Yaris without rubbing. There's a good deal of information about going to wider tires with a lower sidewall ratio but the diameter is usually pretty close. I have run the Yaris specs through a spreadsheet that I use to analyze any vehicle I'm interested in regarding gearing and piston speed. The gearing is quite pathetic and I think should either have a couple more gears or a taller final drive. The engine stroke is 84.7mm. The forward gears are 2.847, 1.552, 1, and .7. With a final drive of 4.237. The stock tires are 175/65-R15. In top gear the speed the piston reaches 5 m/s is 43.01 MPH and the speed it reaches 6 m/s is 51.91 MPH. I think my mostly steady highway driving could benefit from taller tires but it inevitably will come with wider tires and more ground clearance. How tall of a tire is too tall provided that it will fit? Has anyone gone to drastically larger tires with good results? I'm not concerned about the speedometer. I use a GPS as a heads up speedometer. On top of that the Yaris speedometer is trash. It has numbers every 20 MPH and a line every 10 MPH. But don't worry they decided to use the space for some weird dot pattern on the outside that doesn't associate with MPH vs the standard line pattern used on most every other car. |
Every time I put larger diameter tires I see mpg improvement, fatter tires though, are harder to push through snow and slush, hydroplane easier.
I have 195/65R15 from the stock 175/70R14. Ive had 205/70R15 at one time, but used spacers. Car was not as stable at interstate speeds, but the spacers helped some. I liked how it cruised,lower rpm. Around town it would roll farther,no penalty. |
I wouldn't go over a 70 aspect ratio. I also wouldn't go any wider than stock, either. The Insight wheels will improve acceleration, handling, and aero by a bit. I can't see any downsides other than price.
If I crunch those numbers a bit I get the following info. Stock tire size: 175/70-R14 = 23.65" Stable Upsize: 195/65-R15 = 24.98" +5.64% +20mm width Unstable upsize: 205/70-R15 = 26.30" +11.22% +30mm width I would love to switch to a taller narrower tire with the same or higher weight rating. Unfortunately the selection of tires in that size let alone a tire I prefer are limited / non existent. I will do more digging and see how much extra room there is in the wheel wells without adding a spacer. I get my tires through discount tire. I will have to see if they will install larger tires than the listed stock. |
I also see that there is a 175/70-R14 WR-C3 tire available. I recently got a set of Nokian WR-C3 for my wife's 2016 Ford Transit Wagon. We haven't had much snow yet this year to test them but they look capable and have a directional thread pattern and pump sipes that are typically only offered on Nokian's winter only tires to help with wet and ice grip. I calculate my tire sizes in a spreadsheet but they match up to the Nokian catalog. I usually go to two decimal places but the catalog rounds to one. Some quick searching shows that the stock Yaris 15" steel wheel weighs 17 pounds. I think that also included the hubcap. It's actually a pretty decent weight for 15" rims and the hubcaps don't look too bad for aerodynamics. The tires in stock size I'm interested in are Nokian WR-G4 and they weight 15.1 pounds. Keeping stock rims + the tires should give me a tire package weight of 32.1 pounds. The tires have a weight rating of 1100 pounds. Going to a WR-C3 in size 175/70-R14 would be a slightly smaller diameter. The difference would .31" or -1.3%. Honda Insight wheels weigh 10.5 pounds and the tires weigh 15.6 pounds. That would be a wheel package that weighs 26.1 pounds. That cuts a whole 6 pounds per wheel on the car. There is also the improvement of aerodynamics of the Insight wheels vs stock. The WR-C3 have a weight rating of 1520. Despite the small downsize I'm still interested in getting Insight rims. I still need to check with Discount Tire to get prices for moving the TPMS and if they will install larger sizes such as 185/65-R15 and 195/65-R15 tires. I was able to save around $25 per wheels on tires for my wife's van by having them price match tires I found on Amazon. I'm currently on the fence between: Stock size Nokian WR-G4 175/65-R15 with stock rims. Up size Nokian WR-G4 (185 or 195)/65-R15 with stock rims. Slight downsize Nokian WR-C3 175/70-R14 With Insight rims. |
Howdy all,
Just an update. I totaled my 2017 Yaris L hitting a deer. It was around 5:30AM and the deer was on a full run from out of nowhere. I have dash cam footage of hitting the deer. I didn't have time to react so it was a straight on hit close to center slightly passenger side at 55MPH. The drivers airbag, drivers knee, and both side curtain airbags deployed. The drivers knee airbag turned the extra keys hanging from my key chain into shrapnel. I should have saved or at least gotten a picture of the key chain ring since it was twisted up and opened pretty bad. Over all after switching to Mobile 1 0w20 EP over the winter ~10K miles I averaged 38.6 MPG. Since the spring oil change I averaged 39.2 MPG on the lie-o-meter before I totaled the car. I'm currently in the market for a new sub compact. I'm pretty sure I'm going to get a 2018 Toyota Yaris IA (badge engineered Mazda 2 sedan). I almost got a Scion / Toyota IA last fall but the reliability data wasn't really robust yet. On my soon to be new car (2018 Yaris IA) I still want to swap over to G1 Honda Insight wheels. Unfortunately since the 14" wheels and my desire to stick with Nokian tires on the IA the the tires will be 5.14% smaller than the stock tire / wheel package. I'm not sure if the gearing reduction and the dropped ground clearance of 15.625mm will even out as far a fuel economy. 185/65R14 Insight vs 185/60R16 Stock (an odd size with very limited selection). 195/60R16 is the most common size most IA owners use that is close to stock diameter. The good news is that I'm pretty sure the IA has indirect ABS TPMS vs direct so that's one less cost / issue to deal with. On the other hand the automatic has a taller 6th gear and a taller final drive than the manual so it's still probably going to be just fine. |
Sorry to read about your loss, hope you are OK.
Thanks for the keychain info, I'll shorten mine. FWIW, I see better economy on my 175/65R15 steel rimmed winter tires with non-aero hub caps than my OEM 185/55R16 alloy rimmed summer tires. I feel you should not go wider especially if you also raise the pressure. Go for the best quality tires you can get. I lost a car due to crappy tires which wasn't too bad as the car was crappy too ('86 4-gear single cam deasel Rabbit, acceleration timed per calendar). The only reason to get wider than OEM would be if that allows for better tires. |
That is interesting information about how extra keys from a keychain can be bad in a wreck. My Mazda3 came with keyless ignition, so all the keys are in my pocket. Serendipity.
When I changed tires on my Mazda3, I put on 20565R16s in place of the OEM-supplied 20560R16s. The difference is about a 3% taller tire. I just put them on, but the brand new tires did not show any MPG decreases, so they may give me a little boost as they wear-in. My car alarms for flats by utilizing the ABS system. It has worked quite well, and one added benefit is the fact that it let me know when one of my old tires began to experience belt separation. Even though the tire pressure remained the same, the tire grew in circumference due to the belts giving way, so the system let me know because the tires were no longer all rotating at the same speed. This was a real asset to me. Plus, when I changed my tires out, I didn't have to worry about switching or buying new pressure sensors. Again, serendipity. |
Will the new car be a manual or an auto? Manual = better mpg, regardless of gearing (for the most part).
Would 14" rims even fit on the Yaris? With 16s my guess is that anything smaller than 15s might not clear the calipers. Lightweight 15" rims with Bridgestone Ecopia 185/65R15s (Prius eco tire) would keep the same gearing. Prius 15" rims are lightweight at 14lbs IIRC but they're 5x100 vs the Yaris 4x100 bolt pattern. 165/80R15s would give you taller gearing and a narrower tire for FE, but I can't seem to find any that are LRR rated, so FE would likely take a hit unless run at 100 PSI or something insane like that. |
