Where to buy plastic (sheets)
Where is everyone going to buy their sheets of plastic. I can't seem to find any in my area, so what type stores do I need to check with?
sign shops
I'm debating about using spray foam and fiberglass instead. May be easier for me to work with.
that will work it just depends on what you are doing with it and how much you have worked with glass before.
I did spot some 4x8 PVC solid sheets at Home Depot fer around $20...check in the paneling area. Should be right next to the FRP sheets. :D
