Where to find ethanol-free gas.
Ethanol Labeling Laws - State by State Guide.
Most states require gasoline containing ethanol to be labeled as such. Ethanol-free gas stations in the U.S. and Canada This site has a user-generated list of stations where ethanol-free gas is available. The site doesn't verify the information, so it could be wrong our out of date - but in most states, it will be labeled. I'd encourage you to check the label on your gas pump, and add any ethanol-free stations that you know of to the list. Too bad I just fueled up. I would like to try a tank of ethanol-free gas and see what happens. I guess I'll have to wait another 750 miles (fingers crossed!) |
What are they using to oxygenate it? MBTE?
With MTBE banned in 25 states, the answer is pretty much "not outside of Dixie".
But it's a good question. What are the alternative oxygenates? What about underoxygenated fuel? |
the only place that sells ethanol free gas in florida i have found is certain sunoco's. the problem is that the gas is 110 octane and costs about $8.00 per gallon. sort of defeats the purpose of it. although the 110 works great in my banshee atv!
...ah, the (in)famous blue & yellow SUNOCO 260..."street" racing fuel (ha,ha).
Luckily they sell pure gas no ethanol added at a local Shell station here.
i could be wrong however i don't think its the 260. right on the pump it says it contains lead and is not a legal street fuel , the store clerk wont sell it to you if you try to pump it right into the gas tank.
The Cenex stations I've been to have ethanol free gas.
Actually there was an independant gas station in the Keys that sells Ethanol free gas. My guess is most people there use it in their boats. They also sell it for $3.19 a gallon vs $2.79 ish available now. |
bump ...
I was looking around on Google to locate ehtanol free stations in Canada or in my area (Montreal) and I found this post burried in the results! :D pure-gas.org was one of the first thing I found but it's kind of vague. Found other forums where they were discussing ethanol free in Canada and found more details. Turns out all of 91+ octane gas in Canada seems to be ethanol free. Petro-Canada SuperClean 94 (in Montreal only) is also one that many high compression engine owners like to use. With the gas price at 5.5$ a gallon for regular right now I think I'm gonna pass and wait a little. When the prices will go down I will try to see if I can get some premium and look at the FE. |
Just found out the coop station nearby has it... for like $1.40 more per gallon than regular (it’s premium octane).
Even more recently I saw a sign at a new station saying they had E0, but I didn’t inquire about the price. Maybe I’ll run a few tankfulls one day for “science”. |
I do run non-ethanol gas in all of my lawn equipment, generators, pressure washer, and my boat since it doesn't gum up the carbs. Maybe I should run it in the Volt since the tank that's in it is the same one that was in it when I bought it last October |
The really obvious comment: did you do alcohol testing on some samples?
Fuel suppliers tend to WYSINWYG. |
Our ethanol free unleaded 91 octane (no they don't add lead to it) is about $.20/gallon more than the premium 91 octane which is $.20/gallon more than the least expensive 87 octane. Exxon, Conoco, Sinclair, and others all sell it but not every station.
More than anything older snow machines and outboard motors really need it. You put even the 10% stuff in something made 20 years ago by Bombardier or even Mercury and it will melt the inside of the fuel lines, gum up in the filter, lean out the motor under power, and seize a piston. |
The so-called Elantra scandal was a bunch of talkin' head leadfooters who wouldn't work to get 30-40MPG. I knew it before we bought two Elantras, both which have gotten 45-46MPG. For the first year of the 2013 Elantra, using 87 octane 100% E0, I over-all averaged 39MPG (pencil & paper, not car computer). |
Bought some a week ago after googling for ethanol free gas and found a site with this station last updated in 2018. Had it in the middle mosts pumps with a red handle and separate button. Annnnd it was $.50/gal more.
Bought it for kicks. |
I've only burnt clear Premium in the SUPERBeetle since I got it. It is equivalent to the 1971 Regular the car was designed for.
One thing I found in research but haven't tested is that if you try to buy clear Premium on the coast, they make you carry a gas can out to the end of a pier. |
Good News
Murphy USA is constructing (building currently) a brand new fueling station on location way close to where I am located....The promise is that it will have ethanol free fuel there. amen. … BTW there are now several ethanol free threads out there
pure-gas.org now lists 15,000+ E0 sources. Also, New York state now lists 1000 E0 sources within its borders. E0 continues to rise by grass-roots word-of-mouth, only. E85 languishes, despite backing by gov'ts & the "ethanol in gasoline industry". |
