where to get coroplast for mods
Where can I get coroplast for aeromods? if that isn't the best then what is?
I got a few misprinted election signs from a local sign shop's scrap pile, and I believe others here have done the same.
So, find a sign shop, go in, and ask if they have any scrap coroplast. They'd probably be happy to give you some. |
Yes, and you can also buy whole 4'x8' sheets from sign shops for $15-20.
Some fool left a few sheets all in a row on the side of the road near me. Darn litter bugs ;)
LOL, I bet they had the fools name on them in big letters too :)
The signage at most gas/convenience stores are coroplas.
I get lots from a local store that just through it out after the promotion or sale has ended. The pieces aren't huge, generally 3x4 feet or so, but it has been a great source for these and other projects at no cost. |
Can we get an update/additional perspective on this?
Minimum order from Cope plastics is $100, that's 8 - 10 pieces 4x8 x 4mm thick or 5mm in black, look at the specal deals page, fluted polypropylene: I just ordered 13 pieces that I need to pick up.
http://www.copeplastics.com/cmss_fil...ted-8.8.13.pdf |
Check local sign shops or glass outlets. The parent company may give info on suppliers. Also check industrial supply houses such as McMaster-Carr, MSC, or Grainger for materials such as honeycomb aluminum, polycarbonates, and ABS. Election season is coming up and signs are sprouting already
http://www.google.com/custom?sitesea...ORID%3A1&hl=en or use the search button.... 2. local sign store 3. local wholesaler to the sign stores what needs to be updated......someone bringing it to your house?:rolleyes: |
never assume.
links at bottom of page .....put there for the weak & feeble....
Good Coroplast to Coroplast Adhesive? garys_1k DIY / How-to 18 08-07-2010 12:48 PM Where did you buy Coroplast? tjts1 EcoModding Central 28 11-17-2009 09:12 PM Coroplast undertray question (covering the control arms) Otto Aerodynamics 8 03-30-2009 08:27 AM Fastening coroplast to the underbody Daox Aerodynamics 2 05-22-2008 10:57 PM Coroplast question Otto Aerodynamics 14 03-27-2008 07:45 PM |
i got a 6"X3" 4mm sheet for $13.46 at home depot. So let's say $14.
i had to go get myself since mcrews was indisposed at that moment :) |
6 inches x 3 inches..$14...really....
Reread post three....info is very correct Stupid or lazy.....you've got the bases covered! |
Well, some of us actually work for a living. i was very tired; i meant 6' X 3'.
Would appreciate not getting abusive. Thanks. We are all in this together. |
As they say at the meeting of Fellows of the Royal Observatory, "What's a factor of ten to the third among friends?" ;)
Home depot has them in 4x8 sheets, packs of ten for $110.
48 in. x 96 in. White Cap Corrugated Plastic Cardboard (10-Pack)-WC4896-10 at The Home Depot |
