Where to hook up SuperMID to VSS ?
I'm re-installing my SuperMID in my 93 Civic.
It has been so long since I had it installed that I can't remember how I had it hooked up. When I look under the hood at the factory wiring to my VSS, I see that the wiring is uncut ( no spliced wiring ) Any idea where I could have had the VSS routed to, because it was working before . :confused: I plan on routing the power wire to the radio, but again I'm clueless as to where I had it before. Thanks . |
Check the ECU
