Wheres the beep?
Hey, I've got a 91 geo metro. When you turn it on it makes an annoying beep. I'm trying to find the source of this beep so I can remove it, but haven't had any luck. Can anyone help?
Put Your Seatbelt On!
Lol
Hardy har. But seriously it beeps weather or not the seatbelt is on. This annoying beep is preventing me from EOC as frequently as I could. I know I could rig some injector or ignition cut off to prevent the beep, but I just wanna get rid of the beep generator.
1.Turn on your radio.
2.Make sure all doors are closed. 3.Remove the keys from the ignition. 4.Ask someone other than a smart-ass 16 year-old kid like me. |
There is a small black box under the drivers side. Just find it and unplug it. You can see the holes drilled in the side for the opening for the buzzer sound to get out of it.
Thanks, I found it. Mine was mounted directly to the dashboard framework between the hood release and the steering column. It had alot of wires in the connector to it, I unplugged them all and everything seems to still work ok, but no more beep.
