EcoModder.com
-   -   Who makes custom aftermarket pulleys (https://ecomodder.com/forum/showthread.php/who-makes-custom-aftermarket-pulleys-36433.html)
johnathanf1lm 05-05-2018 11:32 PM
I currently have a 2011 hyundai accent gl (nothing model with higher gearing). I am wondering if anyone knows anyone that makes custom pulleys. I want to get a larger water pump pulley to decrease my water pump speed and increase my mpg.
freebeard 05-06-2018 12:32 AM
You could pay custom prices, or scour old parts list for a different pulley that meets the spec.
V-belt most likely?
You have shaft diameter and keyway and overall diameter and width.
johnathanf1lm 05-06-2018 07:37 AM
Its a single v belt. It is held on by 3 small bolts and and a center bore.
