Why bother with batteries
I want one!!!!!!!!!!!!!!
A new power source! This is a momentous event in the history of automotive design.
The plans please!!??!! |
...a "new" use for old TROJANs™?
Killed by the RE - Rear Engined - what were they thinking ? http://www.motorbase.com/uploads/200..._trojan_re.jpg |
...in USA, the word Trojan™ also has the 'street' meaning as to be a prophylatic or condom...also called "rubbers"!
I can imagine that rubberbands wouldn't have a long life in an automotive environment. I once wondered about using a spring instead of a starter.
I would imagine that the energy input to wind a rubber band compared to what you get out is quite large and like a garage door spring, if you have a rubber band or a spring in your car brake... you have enough energy to, as the old magazine says, push you up to 3 miles! that energy is being released all at once! if the chain drive on a motorcycle brakes it can destroy the crank case of the engine, imagine the energy stored in enough gasoline to move you 3 miles all lit on fire at once, it would be about the same as the energy stored in a rubber band that could do the same amount of work.
PW - I also suggested clockwork as a method of Hybrid power. I still think it would work.... ...but I am mad |
um, wouldn't the energy required to wind it be less than the energy released? What is wrong with pedals and a chain in that application?
I wonder the size and weight required for a spring wound starter would be? Hard to get a jump start, I suppose. Or would a pogo stick be a good vehicle to jump off of? |
