05-23-2025, 05:53 PM
High Altitude Hybrid
Why do jacks last only 3 to 5 uses?
I went out to change the winter tires out for my summer tires and guess what, after a single year of use now my jack no longer works.
I had already ruined the jack for the spare tire, so I had bought another one and got a bottle jack.
Well, that bottle jack ended up dying, so I got a better brand one that was much larger. Now it stopped working too.
I can't use a floor jack, my driveway is made of dirt.
I'm getting kind of sick of having to buy a new jack every time I need to rotate tires or change summer rims and tires in and out.
Any suggestions of what jack to get?
05-23-2025, 06:01 PM
I used a floor jack outdoors many times. You can either allow the wheels to burry into the dirt, or put plywood under it.
With the plywood method, that allows you to use a creeper too.
05-23-2025, 06:42 PM
Thanks! I might go that route. But I'm also trying to find tools that fit in my practically "tiny-house" life style. So not a lot of storage for things as large as floor jacks, much less for plywood.
But if a floor jack will not need replacing every season, that's probably the route I should go.
05-23-2025, 07:17 PM
."...a heart can be broken, but a circle goes on forever" -- Bill Keane
05-24-2025, 12:30 AM
aero guerrilla
I had the same!
Pulling the spare wheel jack from the car is hassle, so I bought a dedicated jack changing wheels 2x per year on 2 cars. Nope. After the third wheel it gave up.
And it wasn't the cheapest jack I could find, I made sure I got something a bit better than minimum, but still
The Following User Says Thank You to Piwoslaw For This Useful Post:
05-24-2025, 08:13 AM
Tire Geek
I have a dedicated piece of plywood, and a Harbor Freight Aluminum 1 1/2 ton racing jack. Many years of use. The only thing I've done is grease up the roller. That really reduced the amount of noise is makes when rolling.
Oh and I also made some wooden blocks that fit the pinch welds so I'm lifting at the right location using a large flat surface.
The Following User Says Thank You to CapriRacer For This Useful Post:
05-24-2025, 10:05 AM
20 years of the biggest floor jack from harbor fright, but replaced the pump o rings couple of times
The Following 2 Users Say Thank You to Piotrsko For This Useful Post:
05-24-2025, 10:36 AM
I wonder if my DieHard bottle jack is fixable. All I know is it died hard.
