Why hydrogen powered cars will have poor drag coefficients
2 Attachment(s)
Why? Well, have a gander at the gaping maw on this thing:
http://ecomodder.com/forum/attachmen...1&d=1442238289 (Toyota Mirai hydrogen vehicle: a face only a mother could love) Hydrogen vehicles need big grilles for cooling and also to take in air to process in the fuel cell: Quote:
And the Mirai's drag coefficient? 0.293 Oof! Not exactly class-leading. In fact, pretty far from class-leading. One of the great things about (battery) electric cars is they don't need big cooling systems or exhaust systems, so you can dramatically cut drag using smooth underbodies and no (or much smaller, or fake) grilles. Tesla Model S is a good example: http://ecomodder.com/forum/attachmen...1&d=1442238863 The Model S actually has a pretty big grille on its snout, but it's fake. It's just there for styling. The car's 0.24 drag coefficient is actually top of the class for a production vehicle. |
One of the dirty secrets of FCEV's is they are quite intolerant of heat. And while they are more efficient than an ICE (which is damning with faint praise!), they are a lot less efficient than EV's. So, the heat they generate has to be shed much more effectively than we are used to.
I am not remembering the temperature limit for FCEV's, but it is surprisingly low - and this requires the very large cooling intakes on the Mirai. So, the aero penalty for cooling on ICE's is roughly 10% (if I remember correctly), and it would be higher for FCEV's. |
I can't see the word "maw" without immediately thinking of the original Halo.
Actually, I had been wondering why the Mirai had such large grilles and horrible drag coefficient. Now I'm curious what it looks like under the hood. Edit: Oh...after seeing that interior picture, it's clearer how much Toyota is aping the Mirai with the new Prius. You would think they would have taken the universal criticism of the Mirai's looks to heart. |
Whoa--also, there's this:
"Over 400 miles of driving, the Mirai averaged 56 miles per kilogram of hydrogen, or 57 MPGe." Are hydrogen cars typically that inefficient? |
Hydrogen is a red herring. The sooner we ignore it, the sooner we get to real solutions.
Heat sink hood?
Why would anyone choose the Mirai over the Prius? The only advantage is tailpipe emissions, but then you could simply get the PHEV version and be in a win-win scenario. |
https://upload.wikimedia.org/wikiped..._S.6B_ExCC.jpg |
flush-mounted tubes
The Ford Tri-Motor was all corrugations on the fuselage sides, but because the corrugations didn't taper the laminar flow was trashed and the result was higher drag. It might work better on ground vehicles.
