Will an upper grille block do squat?
Here is my situation, it's very cold out right now but it might get above freezing soon so I can do a little work on my pickup truck (Chevy S10).
My 4WD went out (push button selector not engaging system), I currently suspect the vacuum assisted components GM thoughtfully placed under the battery tray (which can leak battery acid down there) but chasing that possible leak down can be complex I'm told. Therefore as a temporary measure I added four more 70 lb bags of tube sand to the two I already had in the truck bed - that's nearly 500 lbs of sand plus the weight of fuel. I'm not going to get stuck easily. As you can imagine "the get up an go - went up and left" my truck, and I suspect the gas mileage is soon to follow. I don't drive a lot but I can try to up my gas mileage with a partial grille bock. Here is the truck. http://i184.photobucket.com/albums/x...psx85zvetc.jpg http://i184.photobucket.com/albums/x...p/IMGP0363.jpg http://i184.photobucket.com/albums/x...psdd244397.jpg As you can see the tow hook locations are sealed, and the radiator can get no air from underneath. Question is, will an upper only grille block do squat? I would be leaving the lower slit open. Yes I have an electric fan installed, would not even consider this if it still had the old mechanical fan clutch. |
I would do a grille block. In winter it's fine. Watch your temps. Use synthetics for engine oil and transmission since those keep temps down. Using some good quality extra heavy duty coolant will help in that department too.
Cold Front Grille Insert 1998 to 2003 Chevy S10 Pickup or Chevy Blazer#88475 | eBay If you wanna do more on aero, do a coroplast belly pan from old election sign if you have friends in politics. Then get some smaller mirrors. For 94-01 S10 F1 Manual Adjustable Chrome Finish Side View Mirror | eBay Get a wiper cowl too... Lund 25505 Polycarbonate Smoke Shadow Wiper Cowl for Sonoma/Jimmy/Bravada/S10 | eBay Then you can get into friction modifiers for the engine, differential, wheel bearings using NMF and/or tungsten disulfide from lowerfriction.com Have fun. |
and get a tonneau if you don't have...
Extang 2560: Black Max Tonneau Cover S10/S15 1994-2003, 6" short bed Isuzu Hombre | JEGS and an extruded tailgate lip will help a bit too Chevy S10 1994-2003 Wingswest Urethane 3 pc rear tailgate spoiler No light | eBay ...except that one's too big but you get the idea. You wanna trip the air to slow it down before separation. You will know when you drive in the rain/snow and you notice how much wake is behind you. You'll be slicing through the air. |
sorry and do an antenna relocate too since that doesn't need to be flapping out there...
GOLF CART HIDDEN STYLE AM FM AMPLIFYED ANTENNA,.. BRAND NEW + How Too Install | eBay |
...and for your original traction problem, you might want some real tires for colder weather. Nokian WRG3 or Hakkapeliitta for winter.
Cheap insurance |
Of that list I've either already done it, or I am too frugal with my time and money to do it. The upper grille block is quick and easy, I can do that next day above freezing. I need tires, saving up for some Cooper Discoverer STT Pro's, better rated in snow than BF Goodrich and Goodyear AT's, plus designed and made in USA. |
Today and tomorrow it supposed to get up to 36-37 degrees F...................spend the time, or a waste of time?
It's going to take me longer to dig my coroplast (black color) out of storage than to do the block it's self. Maybe this is a two day project, dig out the supplies today, do the work tomorrow. I have a lot of other things to do, but quick little projects like this seem to charge me up. |
I say do it. Seeing the radiator setup, instead of doing just an upper grill block, I would block the center and right (vehicle right, picture left) sections on both the top and bottom. That leaves you the (vehicle) left side open for cooling and what I assume is a transmission cooling line to get air and cooling as well. At your wintertime temps, that will be more than enough to cool the engine down when it finally gets up to thermostat temp.
I'd do it.
upper block
When GM is serious about drag reduction they go with the upper block
http://i1271.photobucket.com/albums/...itled-14_2.jpg So does Ford http://i1271.photobucket.com/albums/...itled-13_3.jpg http://i1271.photobucket.com/albums/...titled-9_2.jpg http://i1271.photobucket.com/albums/...titled1_44.jpg http://i1271.photobucket.com/albums/...titled2_41.jpg NASCAR http://i1271.photobucket.com/albums/...itled24_10.jpg This GM LSR pickup has a 100% block http://i1271.photobucket.com/albums/...titled28_6.jpg You don't have any internal ductwork,and the distance between the heat exchanger and grille isn't large,so be careful. |
I spent some time looking at the situation, dragged out some different materials, tried a few things.
Long story short, this isn't looking like an quick little project, putting it on hold. This is what I found out, To block off the upper grille is not a matter of a simple overlay of plastic sheet material and zip-ties. There are these slots underneath which would also have to be sealed, and it's problematic. I once coated it with Plastic-Dip, no tape will stick to that, plus the pressure would be so great no tape would hold. This means a rigid material on the slots, and one would see the leading edge, an edge which would grab the incoming air. S10 4x4 Pick Up by George Kachadoorian | Photobucket http://i184.photobucket.com/albums/x...psz57nr5ux.jpg http://i184.photobucket.com/albums/x...psbmn5gsaf.jpg I test fitted a left over piece of conveyor belt, it would be a real bugger if not impossible to get to seal. http://i184.photobucket.com/albums/x...psz52whosm.jpg Dead in the water. I'm not going to remove the front grille to do the work from behind, the plastic and the clips are 18 years old now, and the low temperatures do not help. Not going to chance breaking it. http://i184.photobucket.com/albums/x...ps7euxqjpv.jpg |
