Window Efficiency
The door to door salesmen are out in force today. 2 different guys stopped by asking if I wanted a quote on a new roof and windows.
One guy said their windows are filled with krypton gas. I haven't researched this yet, but is this the preferred gas these days? How does the window retain the gas for so many years considering tires leak air all the time. The spacers/seals on my south-facing windows have cracked and let minor amounts of moisture in, which is visually unpleasant, but I'm wondering how much energy I might be loosing through them? Is the loss of the inert gas significant enough to be concerned? The sales brochure says the spacers they use are made of HPH. No idea what that is, but I'm wondering how it holds up to sunlight over the years? Anything else I should know about windows? |
Argon is also heavier than air, I watched a "How It's Made" episode on how they fill them.
They take a small hose and insert it into a hole at the top of the window and slowly fill it so the argon replaces the air, then they cap off the hole. The new double pane argon filled low-e 2 glass horizontal slider windows I installed recently (I got a great deal on Craigslist from a couple who bought them new but never installed them) definitely make a big difference in heat/noise reduction where I closed in my lanai and made a sun room out of it. It was well worth it to me since I got them cheap and did the installation myself Will you ever see an ROI on a window investment if you buy new and have them installed? Doubt it, since most people don't stay in their homes long term these days, but it's more comfortable and quieter for sure while you're there, and it's a selling point if you have upgraded them in an older home! |
Danged if I know what gas they put in these days...but I replaced our windows with double-paned, whatever-gas filled (rated for most of canada, even though we live in a warmer zone) and it cut our heating and cooling costs in half over the single-paned ones the place came with.
Our heat and/or AC used to stay ON the whole time when it was cold or hot, and now it just cycles on for half or less of the time. More than noticeable difference. |
Does a double-paned window act similar to a single after the gases have escaped?
I'll likely be moving in about 3 months and renting the house out, so maybe I shouldn't bother. I can buy new balancers for the ones that have broken. What I really need is a new roof. I was going to do it myself, but don't have time anymore. |
I asked a window salesman how long the gas would last before full leakage a few years back just to see if he would be honest. Much to my surprise he told me that they are generally good for 5 to 8 years. I expected him to say the gas would never leak out. Regardless, even without the gas, two panes should still be better than one since a small air buffer is still being provided.
JJ |
I have air filled windows.
I would like to develop a way to argon fill and refresh them. Since I already have argon for welding. I highly doubt that there areally any Windows filled with krypton. It cost at least $700 for a 330 cubic foot bottle. A 330 cubit foot bottle of argon should be less than $100. Bulk refrigerated liquid argon would be cheaper even per unit. |
Well the first round of salesmen are finally gone. I figured they would stake some measurements, type out a quote, and email it to me. They took way longer than I expected; 2.5hrs.
Do I want low-E windows in my climate? I enjoy not having to run heat in the spring and fall due to solar heat gain, but does low-E also retain heat better in the winter? Can I still get solar heat gain with the visible light, or is solar heat gained mostly through infrared? The guy said there are only a few companies that offer Krypton filled windows. Don't know that I'd want to pay extra if it only keeps for 5 years. Not only that, but I'm only replacing the south facing windows. I would think the extra insulative value would be compromised by the existing north facing windows, which have probably lost any gas they were filled with. EDIT: Just found this... Quote:
Lower emissivity slows down heat transfer.
I have double paned windows...17 years old and climbing.. not gas filled. Seem to work pretty well... especially since I installed solar tint on the outside panes. Wow... what a difference and they say the solar film blocks heat better than any window made. 70% of the solar heat is blocked and 99% of the UV rays. I spent under $500.00 installing the film myself and it looks fantastic. BTW, if you're not a person that is fairly handy and doesn't pay attention to detail, then don't try to install yourself. Precision is key. In window tint...cleanliness is Godliness.
+1 for the solar tint.
Made a HUGE difference for me in the summer time. |
Even though I currently live in an apartment, and finding suitable double-paned windows for it is not so easy back here, it's something I do consider to use whenever I move to a house. Other energy-saving features would also not be out-of-question.
Sorry I did not post this earlier, but I think that for some applications, glass brick make sense. What is the R-value?
Have a great day! |
Plus which it's structural. Offsetting that it would cost more, I suspect, than double-pane glass.
The problem with glass brick is that it won't open like a regular window would. But anyway, considering that it would provide enough luminosity and allow the use of smaller windows, might offset the cost.
phys.org:Solar power advances possible with new 'double-glazing' device
cleantechnica.com:Scientists Channel Tesla & Einstein To Invent New Double-Glazed Solar Panel Two sources so you can compare the reporting. I like both but generally prefer phys.org; they're usually out front. In this case 2 days earlier and include a journal reference in addition to U of Warwick. Anywho, this is Steampunk Stuff. :thumbup: Two transparent surfaces, one electrically conductive and one with a sputtered coating of [diamond] with the cavity filled with argon. This is low-rent high-tech. |
But anyway, if I were going to build a new house, or eventually refurbishing an older one, I'm sure I would look at some options on "efficient" windows. |
The new place I'm at has front doors you can see light coming from around the edges, and some doors are so poorly placed you can see into the home. |
By low-rent I meant to imply low-cost or home-brewed.
I was thinking of a 'post apocalyptic' or maker-scene scenario. Maybe I should have emboldened steampunk. |
If you want low-rent double-paned, then you probably just want this ;-)
https://www.walmart.com/ip/Duck-Bran...-Pack/17510819 |
You can use the window kits (heat shrink plastic stuff) to make double-sided interior inserts. There's instructions on the interwebs but basically I ripped some pre-primed 1X4 pine in half and made a frame that's about 1" smaller in both dimensions. You use double-sided tape to hold the plastic (on both sides of the frame), shrink it, put a layer of clear packing tape around the perimeter (to help hold the plastic) then finish off with a layer of appropriate sticky-back foam all around. If you get the dimensions right, it just pushes into place with a smooth "swoosh" sound. You put pieces of tape doubled over on itself at the bottom (sticking out under the foam) to remove it for summer months or whatever.
You get two extra air spaces and a reusable insert for a reasonable price. These are especially effective in older, leaky windows. You can buy materials in bulk online to save on costs. |
I use double-wall greenhouse glazing I bought as scraps. The flutes run horizontally and act like a shiny venetian blind, reflecting light back up to the ceiling.
