wiper closer to the car
today i had an idea. the wiper arms of my car are not so close to the body, as i wanted them to be. so i spend some time, fiddeling with file and wrench. i tried to make the hole somewhat deeper and with an angel, to set the wiper arm closer to the car and more hiding behind the hood.
after the intial filing, i pushed the wiper omto its shaft and in the right position, and moved the arm to grind it in. the drivers arm is now about 4mm, and the other is 5mm closer to the car. sounds not mutch, but looks good for me. http://img441.imageshack.us/img441/8...cf5088m.th.jpg http://img856.imageshack.us/img856/5...cf5089d.th.jpg |
I can take the wipers clean off and not be able to detect any differences. If you can detect a reduction in wind noise perhaps you are on to something.
Yeah- my ol' skool 3-box cars and trucks. His Prius is sorta 1-box so...?
The Prius? I wasn't aware it had /any/ box... :)
itīs the santamo, not the prius.;) notice the korrosion? this canīt be the prius!
in fakt the prius is better shaped, but i will give it the same trick, once i will oil the wiper shafts. it costs nothing but a little efford. and the car is better looking. i know, i know, looks are not important for a hypermiler...:D |
Wiper blades will make almost no difference to the drag. Try putting a small leaf or blade of grass next to the blade, and then drive. Unless you get a crosswind, it will probably stay put.
I recon with this windshield mod you'll save at least 8mL of gas every year!! :eek: |
On cars where the bonnet and windshield form (nearly) one line like the prius and others, there's no or not as big a bubble for the wipers to hide in. Hiding the wipers is good practice as it reduces pedestrian injuries in case of an accident. |
Mileage gains (or lack thereof) notwithstanding, I like the mod simply because it looks cleaner. Not everybody here has an appreciation for form-enhancement (most of us are function > form types), and I likely wouldn't spend the time to do this unless I had a few mins and a spare set of arms around, but I can appreciate that it is an enhancement, nonetheless.
One thing to pay attention to, however - Doing this has lessened the leverage that the arms have over the blades. There's a chance that wind gusts, etc can now lift your wipers, and they may not work as well during rain. The fix, if this happens, is installing stronger springs under the wiper arms. |
i use these aerotwin wipers. they donīt tend to lift, and until now is no diffrence remarkable.
