EcoModder.com
-   Success Stories (https://ecomodder.com/forum/success-stories.html)
-   -   Woo-Hoo! final broke 45! (https://ecomodder.com/forum/showthread.php/woo-hoo-final-broke-45-a-38462.html)
laser3kw 06-30-2020 08:36 PM
45MPG! :thumbup:
I don't post here much, but do lurk quite often. Most of my mods are inspired by things I find here.
I got my 2000 SC1 w manual trans about 12 years ago? It's been my daily driver, to work and back, 44 miles round trip, half highway and half through town, 31 stop lights ( I average full stop at only 10 or so).
I found a engine in a junk yard with only 1000 miles on it and swapped it in before I had it for 3 months. It now has 100000.
As a hobby, I record every fill up and calculate MPG. I have done some modifications, HAI, alternate spark plugs, wires, AFR gauge (real time), header, smooth hub caps, 15" rims and taller tires.
I drive it very conservatively, and historically, around this time of year, I normally see 40~42mpg. This year, with the above mods, non-ethanol gas (new -this year), and careful driving, I have recorded 3 thanks at 45, 45.46 and 45.51 mpg. :)
I think I will see a bit more if our temps hover in the 90's for a week or two.
I am testing the non-ethanol gas this year. It is a solid 10% better after 4 fillups (around 9 gallons each)
Ecky 06-30-2020 09:08 PM
Nice job! 45 is definitely respectable.
Ethanol free gas was instrumental in my hitting my goals recently too. However, I did not see 10%, but rather my fuel trims changed by around 3% and I had to correct my fuel tables by 3% - which is almost exactly the difference in energy content between E10 and E0.
California98Civic 07-01-2020 11:07 AM
Cool! You swapped the engine just because the one in the yard had so few miles, or because yours had died? Either way, great results.
Daox 07-01-2020 02:26 PM
Very nice job!
laser3kw 07-01-2020 07:45 PM
I got the car after hunting for several months for a Saturn SC1 with a manual trans and some nice accessories. Like a lot of Saturns, it was rode hard and the motor used some oil. I happened across the engine in a junk yard listed on Car-Parts.com. The car had been hit in the rear and only had 1000 miles on it. I paid $350 for the motor complete and between winter (to cold) and lack of time, it took me a year to get it in.
Since then I have kept it well maintained with PAO synthetic (Schaffer's 9000) and good filters (extra capacity filter). I just changed the oil (6000 mile interval) and has not burn more than a pint or so.:thumbup:
I will be turning 200,000 miles by the end of July. :D
Ecky 07-01-2020 08:54 PM
And here I was thinking it was just that all of those engines used oil.
laser3kw 07-02-2020 08:14 AM
I get that a lot!:o
I have been built and maintained engines long enough to know what kills them - improper / lack of maintenance and driving them hard. I do neither.
The SOHC 1.9 motor makes a whooping factory rated 90 hp - maybe! Most drivers are impatient and drive WOT between stop lights thinking they are getting somewhere. That will burn up these little motors quick.
